RS6 front brakes onto RS4 B5
2.7 V6 30v biturbo - 380 bhp
blackb1ade
Post by blackb1ade » Thu Apr 26, 2007 8:22 pm
I've noticed a pretty dramatic imbalance since the upgrade, but that's because my rears are completey shagged! - will be replacing the discs with the (aesthetically matching) GMBH crossdrilled jobbies and have the calipers overhauled at the same time - apparently that's all she needs (as per the above testaments)
Another thing to consider (as I'm pretty sure it's contributing to the fiesty 'squirming' under hard braking at speed on mine) is the state of your dampers - again I'm about to upgrade to the slightly firmer Konis - but even if I were to replace with brand new OE gear I think that would eliminate the issue as, on anything high performance, almost 6 years of road use and 63k miles has got to mean they're well past their 'thrash by' date ;-)
soapy_g
Post by soapy_g » Fri Apr 27, 2007 7:34 am
Cheers guys , thanks for the vote of confidence !
EDDY,G
Post by EDDY,G » Sat Apr 28, 2007 10:33 pm
have you looked at the ottinger rs6 upgrade brake kit a freind of mine is running them .. megga megga stopppers look sexy as hell to boot :) he said he had to do no mods to mountin brackets ... gotta be worth a look in my view !
B8 S4 red
335D TOURING 700nm. sold
09 V10 RS6 GUNMETAL
EVO9 MR FQ360 480/450 sold
04 rs6 black sold
01 noggy rs4 , short shift ,ottinger rs6 upgrade biiig break kit , bilstiens, no cats + mrc custom remap !....04 ebony rs 6 with.. tints and all the toys ! sold
e46 alpina b3.4 s..sold
e39 m5 ..sold
e36 m3 evo..sold
civic type r track bitch..sold
blackb1ade
Post by blackb1ade » Sun Apr 29, 2007 9:42 am
No extra brackets IIRC, but you'd have to factor in to the price kitting it out with 19" rims - wont fit inside an 18" wheel if I'm correctly informed?
soapy_g
Post by soapy_g » Thu May 03, 2007 7:19 am
I am planning to give myself a week or two to let the newness experience settle ( and the car) then get it off to Bem Ho's shop in HK to take a look at the brakes on it, plus a general healthcheck from a specialist point of view. Satrting to save me pennies now...
Have to say i am starting to get used to the brakes not being as responsive as my old 993's :P
blackb1ade
Post by blackb1ade » Thu May 03, 2007 2:21 pm
Yes, I've found you just...well...press harder :lol: Mind you, takes a little getting used to if I step back into the RX8, I nearly put the missus through the windscreen the other day punching the brake - bt of a difference in response...(at least that's my story and I'm sticking to it... :bigblink: :mrgreen: )
TopBear
Post by TopBear » Fri Sep 07, 2007 7:46 pm
derdle wrote:
iirc brackets only required if using RS6/+6 discs as they have different offset to B7 discs
That's why I remember brackets being put on my car then!
Is this definately the case then, can anyone who's done the brakes upgrade themselves confirm that there isnt anything more req'd other than the RS6 calipers,B7 discs& B7 pads....... i.e no brackets req'd to adapt to the B5 RS4 ?
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
Nige_RS4
Post by Nige_RS4 » Fri Sep 07, 2007 7:58 pm
You might want to invest in a set of braided hoses to replace the OEM RS4 ones as they are a bit tight (but they will suffice apparently).
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
CliveH
Post by CliveH » Fri Sep 07, 2007 7:59 pm
Correct :thumbs:
Clive
TopBear
Post by TopBear » Fri Sep 07, 2007 8:02 pm
Nige_RS4 wrote:You might want to invest in a set of braided hoses to replace the OEM RS4 ones as they are a bit tight (but they will suffice apparently).
Cheers Nige, is there any particular spec\type or part to get? Any recommendations where to get em from as MRC are closed for a week and my need is urgent. Did you do the RS6calipers/B7RS4 discs\pads upgrade?
CliveH
Post by CliveH » Fri Sep 07, 2007 8:05 pm
You could also use the RS6 flexi hoses.
Clive
TopBear
Post by TopBear » Fri Sep 07, 2007 8:06 pm
CliveH wrote:
TopBear wrote:
derdle wrote: That's why I remember brackets being put on my car then!
Correct :thumbs:
Nice one, thanks.... :)
TopBear
Post by TopBear » Fri Sep 07, 2007 8:16 pm
CliveH wrote:You could also use the RS6 flexi hoses.
Any part numbers (if you know them) would be appreciated :wink:
CliveH
Post by CliveH » Fri Sep 07, 2007 8:31 pm
4B3 611 707 A
Clive
TopBear
Post by TopBear » Fri Sep 07, 2007 10:55 pm
Apologies for being anal about this, but does this pick list look OK, everything I need?
Also, brake pad sensors... do they connect up without any modification to the B7 pads?
Users browsing this forum: No registered users and 65 guests
