Can vagcom code in a replacement ecu?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
lengster1
Post by lengster1 » Mon Aug 27, 2007 11:40 pm
I need to change a duff ecu on a 99 a4 T sport im led to believe they need coding in to synchronize the immobilizer,any here done it before? Im still learning my way around vagom any pointers would be a big help guys
S2tuner
Trader (Expired)
RE: Can vagcom code in a replacement ecu?
Post by S2tuner » Tue Aug 28, 2007 10:49 am
What's the part number of the ECU you need to replace? If you're lucky, VAG Com can do it, if not, a trip to the dealer's and a few notes less in your wallet will get it sorted...
lengster1
Post by lengster1 » Tue Aug 28, 2007 5:09 pm
Part no 8do 907 558e
S2tuner
Trader (Expired)
Post by S2tuner » Tue Aug 28, 2007 10:13 pm
You should be able to recode it with VAG-Com. Go to Instruments (address 17), then adaptation (10), read channel 00, test and save 000 in there then see if the car starts. if not, repeat procedure in Immobilizer (address 25), as this car is likely to have a separate immobilizer control unit.
HTH,
Mihnea
lengster1
Post by lengster1 » Tue Aug 28, 2007 11:04 pm
Thanks Mihnea i will try this tmrw morning before i trailer the car into the stealers at 1 oclock,I hope i can fumble my way through it ok,The car only has one key and its plain non remote type,Do i need to obtain any codes from the origonal ecu before i remove it?Or is test and save 000 the code? Thanks for your help im enjoying the learning and appreciate it
S2tuner
Trader (Expired)
Post by S2tuner » Wed Aug 29, 2007 9:30 am
You don't need to obtain any codes as it's very likely that you have IMMO 2, not 3. Keys have nothing to do with allowing a new ECU to run in the car, so just follow my procedure and you should be fine ;)
lengster1
Post by lengster1 » Wed Aug 29, 2007 11:04 am
WooHoo all sorted she runs just fine,Thanks a million Minhea,were do i find out all these procedures is there anything i can buy?Have elsa but need a bit of help getting up to speed with vagcom
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 40 guests
