light grinding noise from rear brake
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
lordlip
Post by lordlip » Tue Aug 14, 2007 8:42 pm
Hi all can i please try and delve into the bottomless pit of info on here as i have developed a slight grinding noise under light - medium braking, there is also a really quite annoying squeak coming from the same drivers rear wheel . Had the car up on ramps today no obvious signs of anything whilst slowly rotating wheel there is a squeaky creaky noise (specific i know!) discs and pads only 6month old any ideas ?
Too many mods - Not enough overtime !
yorkie
RE: light grinding noise from rear brake
Post by yorkie » Tue Aug 14, 2007 8:50 pm
All the time or just after wet weather?
All my disks make a right racket for a short time after the car has been out in the wet and allowed to dry off.
You can almost watch the rust growing!
lordlip
Post by lordlip » Tue Aug 14, 2007 8:52 pm
all the time tried a good jet wash and a emergency stop but still does it started about 4 days ago really getting on my tit end now :bash:
yorkie
Post by yorkie » Tue Aug 14, 2007 9:01 pm
Wheel bearing then maybe?
s4woody
Post by s4woody » Wed Aug 15, 2007 1:15 am
is the plastic arb link ok..when the ball joint on them dry's up they can squeek..also check its not broken and rubbing under braking
GARTH ROAD MOT CENTRE LTD
020 83353032
mikeyquattro
Post by mikeyquattro » Wed Aug 15, 2007 8:59 am
Maybe a warped disc......
Tomorrow is another day
lordlip
Post by lordlip » Wed Aug 15, 2007 7:01 pm
would a warped disc rub all the time or just under braking ?
mikeyquattro
Post by mikeyquattro » Wed Aug 15, 2007 8:31 pm
could be all the time. Can you get access to a dti or put a stand next to the disc so when you rotate it you can see if the gap changes
lordlip
Post by lordlip » Wed Aug 15, 2007 9:37 pm
ive got quick fit stripping it down cleaning and re-building for free on sat see what they say
Harper--D
Post by Harper--D » Wed Aug 15, 2007 9:53 pm
Hi there, Try replacing caliper as both of my rear calipers have seized up in the past!! Causes spqueking ALL the time and grinds under braking(not heavy) This should solve your problem!!
Dave.
White MK2 Golf.. Slightly modified :D
MarkB
Post by MarkB » Thu Aug 16, 2007 8:53 am
Yes, I've had to replace both rear calipers after they seized. Common problem with VAG rear calipers
Mark
lordlip
Post by lordlip » Thu Aug 16, 2007 8:02 pm
that would be sods law after they`ve only recently been painted what sort of cash am i looking at for a new caliper ?
lordlip
Post by lordlip » Sat Aug 18, 2007 8:31 pm
right well quick fit said they couldnt find anything wrong should have guessed with them but worth a try for free had a good look and nothing seems broken arb link wise so any other possibility's as its doing my head and really dont want to go to the stealership
Harper--D
Post by Harper--D » Sat Aug 18, 2007 9:01 pm
Try MRC Tuning @ info@mrctuning.com. Doug should be able to fit you in!! I can't see it being anything else as it is very common on these cars for the rear brakes to seize!
Dave.
s4woody
Post by s4woody » Sat Aug 18, 2007 9:34 pm
he lives in hull..if his brakes are sticking on..he'll need new disc's and pads just for the drive there..
020 83353032
