light grinding noise from rear brake
Hi all can i please try and delve into the bottomless pit of info on here as i have developed a slight grinding noise under light - medium braking, there is also a really quite annoying squeak coming from the same drivers rear wheel . Had the car up on ramps today no obvious signs of anything whilst slowly rotating wheel there is a squeaky creaky noise (specific i know!) discs and pads only 6month old any ideas ?
Too many mods - Not enough overtime !
RE: light grinding noise from rear brake
All the time or just after wet weather?
All my disks make a right racket for a short time after the car has been out in the wet and allowed to dry off.
You can almost watch the rust growing!
all the time tried a good jet wash and a emergency stop but still does it started about 4 days ago really getting on my tit end now
Wheel bearing then maybe?
is the plastic arb link ok..when the ball joint on them dry's up they can squeek..also check its not broken and rubbing under braking
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
- mikeyquattro
- Top Gear
would a warped disc rub all the time or just under braking ?
- mikeyquattro
- Top Gear
could be all the time. Can you get access to a dti or put a stand next to the disc so when you rotate it you can see if the gap changes
Tomorrow is another day
ive got quick fit stripping it down cleaning and re-building for free on sat see what they say
Hi there, Try replacing caliper as both of my rear calipers have seized up in the past!! Causes spqueking ALL the time and grinds under braking(not heavy) This should solve your problem!!
Dave.
White MK2 Golf.. Slightly modified
Yes, I've had to replace both rear calipers after they seized. Common problem with VAG rear calipers
Mark
that would be sods law after they`ve only recently been painted what sort of cash am i looking at for a new caliper ?
right well quick fit said they couldnt find anything wrong should have guessed with them but worth a try for free had a good look and nothing seems broken arb link wise so any other possibility's as its doing my head and really dont want to go to the stealership
Try MRC Tuning @ info@mrctuning.com. Doug should be able to fit you in!! I can't see it being anything else as it is very common on these cars for the rear brakes to seize!
Dave.
he lives in hull..if his brakes are sticking on..he'll need new disc's and pads just for the drive there..
020 83353032
020 83353032
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 61 guests
