Aquamist System.
Chubby
Aquamist System.
Post by Chubby » Thu Jul 26, 2007 8:02 am
Has anyone who has fitted an Aquamist system, got any data on IAT drop of performance related data?
And where do you get the water tank from that fits in the tyre well..???
And is it worth it?
R.
RS4 Misano Red (The Fast Colour) - A Few Extras = 550bhp - In Love Again - Now broken - Hate the Bitch... Has to go...
GT-R arriving 14/05/09 - Too many toys - not enough time...
tolga
Post by tolga » Tue Jul 31, 2007 2:42 pm
Yeah, I have Aquamist 2D. At about 2 degrees ambient temp., it made a difference of 9 degrees celcius at redline in IAT. Using RS4 ICs BTW. Definetely worth the mod. You can get similar results from FMIC I guess. Test was done with MTM Stage3 program running. I did not test it with much higer ambient temps but I guess difference should be about the same...
Using OEM ICs I am now running around 2 bars of boost with not much of a knock; I guess I owe it to Aquamist alond with some other mods. Hope this helps...
Chubby
Post by Chubby » Wed Aug 01, 2007 1:46 pm
Have ordered a 2D system - any fitting points thatyou know that could assist me in fitting for the first time?
What water tank do you have and where did you fit it?
Regards,
R.
davs4
Post by davs4 » Wed Aug 01, 2007 3:35 pm
I use the washer bottle on mine :thumbs:
tolga
Post by tolga » Thu Aug 02, 2007 8:50 am
I use the washer tank too, it is suitable for a daily ride but may not be for track use...
As for the fitting points: go ahead and get 2ea. 4mm jets and a T for splitting. Then, locate the flex pipes on the IC exits (right behind the head lights). One side goes to the IC, other side to the pipe that connects to TB. Loose the flex pipes and get two metal pipes (3" diam. as far as I can remember) with about 10cm lengths. Place the jets on the pipes and put the pipes in place of the flexes (with jet exits pointing up for easy connection of WI lines) with the help of silicone joints. Routing WI lines should not be any problem...
You're ready for a cooler ride 8)
T
MarkB
Post by MarkB » Thu Aug 02, 2007 1:35 pm
tolga wrote:I use the washer tank too, it is suitable for a daily ride but may not be for track use...
T
Any pictures of your install?
Mark
tolga
Post by tolga » Tue Aug 07, 2007 9:07 am
I found this, hope it helps...
ZeroK66
Post by ZeroK66 » Tue Aug 07, 2007 8:27 pm
Doesnt brett run this and has done for a long time with great results?
2001S4ICS
Post by 2001S4ICS » Tue Aug 07, 2007 8:30 pm
ZeroK66 wrote:Doesnt brett run this and has done for a long time with great results?
Hey man OT but what size injectors are you running>?? do you have allmost all the same mods as Mihnea??
2001 Stage 2+ S4
GIAC Software
AWE
Clutchmasters
Stasis
Piggies
Hyperboost
FMIC
RS6s or GTs coming soon ;-)
ZeroK66
Post by ZeroK66 » Wed Aug 08, 2007 3:48 pm
I have exactly the same setup as Mihnea - only difference is standard flywheel and RS4 clutch - school boy error! Injectors are: 728cc/min injectors at 4 Bar rail pressure according to their site. Not sure what injectors they are.
Sorry about the OT...
Chubby - PM BRETTCOLLINS he will tell you about his experience. He helped me when I was considering this.
mattsimis
Post by mattsimis » Thu Aug 09, 2007 9:34 am
Im running the simpler and cheaper 1S Aquamist. Using 0.6mm jets (dual). Be sure to get the checkvalves too to stop water siphioning and turbo imbalance. I would also recommend the APR bipipe as I could never get a perfect seal on the plastic original bipipes.
At the moment pushing 28PSI peak through the stock ICs (installing the IPPs ones this weekend) with no issue. We should run a few Vagcom tests and see how all these approaches compare!
V10 5.0 Phaeton now and 2.7T Allroad
Chubby
Post by Chubby » Sat Aug 18, 2007 5:04 pm
Thanks for the advise guys, I have installed most of the parts, just need engine back in to fully hook up, have made a seprate tank to fit in wheel well, but so far everything looks good.
R.
dazzer
Post by dazzer » Sat Aug 18, 2007 5:49 pm
Chubby wrote:Thanks for the advise guys, I have installed most of the parts, just need engine back in to fully hook up, have made a seprate tank to fit in wheel well, but so far everything looks good.
R.
I can concur that it does look good.
Peakz
Post by Peakz » Sat Aug 18, 2007 10:44 pm
Yes Richard, well done for doing a sterling job on that. . . watching Blue Peter in your formative years has certainly helped!
Just the small matter of resolving your cracked heads now, I doubt papier mache will fix those though.
Chubby
Post by Chubby » Sun Aug 19, 2007 11:21 am
I'm going for a new set - just need to find a place to buy the little bleeders...
Users browsing this forum: No registered users and 58 guests
