Pics: Hood pins beeing mounted on my RS4. This hurt to watch
2.7 V6 30v biturbo - 380 bhp
>RS4<
Post by >RS4< » Fri Jul 27, 2007 4:52 am
Dude..........I have the deepest respect for you,regarding this project (and your wallet..... :wink: )
An opinion is like an asshole,everybody has got one.
dodgydave
Post by dodgydave » Fri Jul 27, 2007 10:20 am
Doug_S2 wrote:please say you can go to the ring in september so we can have a good look at this?
what spec k16s are they?
are you using the stock fuel rail for 900bhp?
The K16 look the same spec as the once I use!!
The fuel rail is not sufficient for 900hp nor is the intake manifold. Also the RS4 throttle plate is only really good for 600hp. So, you're already pushing the envelope running 750hp on those bits. Loads of backpressure in the intake system. Solution is a larger fuel rail and 2 throttle bodies with 2 custom intake manifolds. Unless you know where to get a 95-100mm throttle body? And of course running speed density with no MAF or 2 MAFs.
Apart, from that the rest will cope to deliver 900hp on race fuel tho !!!
So, I'm looking forward to see his results and hopefully both our cars will be ready for the Ring.
My engine is going in THIS weekend and then another week for building the exhaust. Fingers crossed!!! So, I will be down at yours next weekend. ;o)
CAN'T WAIT to finally drive the fruits of 14 month building (well, mostly waiting for parts tho !!!) ;o)
The K16 will fit all original K04 oil, water etc lines with a bit bending here and there. The difficult part is the actuators because there is very limited space. Also if you don't weld the compressor housing as the Dahlback turbos in the pic earlier you'll end up cutting the subframe for one of the charge pipes. So, the easy way would be getting your K16 compressor housing pre-welded.
musty1
Post by musty1 » Fri Jul 27, 2007 1:35 pm
Dave you meen something along these lines :wink:
Engine
Mangement: Autronic stand-alone ECU
Engine block: Stock
Heads: Euro 2.4 liter V6 ALF code (now converted to mechanical valve actuation)
Crankshaft: Stock
Camshafts: Cat Cams 280’
Connecting Rods: Pauter
Pistons: JE pistons
Turbos: Precision Turbo PTB 300-5032 ball bearing
Intercooling: Custom Kreator Mocy dual core FMIC
MAF: None
Injectors: 800 cc @ 3 bar
Fuel Pressure Regulator: 5.5 bar
Ignition: Autronic Spark Module
Nitrous: Twin wet (fuel & N2O) systems-150 hp Nitrous Express and 200 hp TNT
Compression ratio: ~8:1
Boost (absolute): 3.5-4 bar
Horsepower (without Nitrous): ~800-1000 hp depending on rev limit
Torque (without Nitrous): ~1100 Nm (810 ft-bs)
Horsepower (with Nitrous): 1000+ hp (violent spool difficult to measure on wheel dyno)
Redline: 8,000-10,000 RPM
Drivetrain
Transmission: Stock
Front Differential: Quaife LSD
Center differential: Stock Torsen
Rear differential: Stock
Front halfshafts: Audi 100
Rear halfshafts: Stock
Clutch: Twin spring S2/RS2 race clutch
Flywheel: Single mass Audi S2
dodgydave
Post by dodgydave » Fri Jul 27, 2007 2:12 pm
On second view I think that I have a lager exhaust housing if the dark coating doesn't just make it just look smaller. I'm on a 8. housing and I think his looks like a 7.
But a 7. won't be able to deliver 450hp !!! The 8. does around 400hp+
b^kiinuut
Post by b^kiinuut » Fri Jul 27, 2007 3:19 pm
Forgot to tell you that the rims I bought for my car in the first place did not fit. The MTM Bimoto rims will have to do the trick...
It looked a little like this when we tried them on the back. The brakes in the front are just to big, lol.
Schmidt Revolution VN-Line Radinox. Special ordered with a black center. The olny set of it's kind in existence so far.
okkim
Post by okkim » Mon Jul 30, 2007 6:04 pm
How is the standard engine block going to stand the +700 HP? I know one engine which is going to have "corset" between the oilpan and block so it will not twist and break.
Has anyone cracked the block from the crank side?
dodgydave
Post by dodgydave » Tue Jul 31, 2007 1:07 pm
okkim wrote:How is the standard engine block going to stand the +700 HP? I know one engine which is going to have "corset" between the oilpan and block so it will not twist and break.
The V6 doesn't need this mod as it has double bolts on the bearing caps. And another 4 bolts from the side to stiffen and align the bottom end.
I reckon you can drive up to 1000hp with no trouble at all. With different rods though. ;o)
okkim
Post by okkim » Tue Jul 31, 2007 1:27 pm
Is this a fact? I know that it has those bolts, but one tuning company is making this "corset" to one engine. They are tuning it for 900 hp. I would like to know that what is the maximum power taken out without any modification to crank or in that area.
That Polish S4 does have a lot of power (+900), is that modified from the crank area?
dodgydave
Post by dodgydave » Tue Jul 31, 2007 4:25 pm
okkim wrote:Is this a fact? I know that it has those bolts, but one tuning company is making this "corset" to one engine. They are tuning it for 900 hp. I would like to know that what is the maximum power taken out without any modification to crank or in that area.
The polish one drives a stock S4 crank and block !
musty1
Post by musty1 » Tue Jul 31, 2007 4:27 pm
far as I know the polish s4 does not have the corset
reserves
Post by reserves » Thu Aug 02, 2007 9:37 pm
Looks amazing! nice work.
SnowTrooper
Post by SnowTrooper » Thu Aug 02, 2007 10:45 pm
the stock rs4 throttle body can support the power levels claimed...
car looks awsome, let me know if you want to sell the old gearbox
Jared @ STaSIS Engineering
2000 s4- two turbos, quattro, lots of kevlar, CF and aluminum, slicks, a welded rear diff, weird paint and about 700 hp
1990 CQ- Bone stock, racks, studded tires = ski car
b^kiinuut
Post by b^kiinuut » Fri Aug 03, 2007 1:49 am
SnowTrooper wrote:...let me know if you want to sell the old gearbox
Sorry, but the old gearbox is 6 feet under because of some heavy mistreatment ...
C-24
Post by C-24 » Sun Aug 05, 2007 8:45 pm
The car is incredible.
How much does it cost to pay the annual tax for that much horse power ?
S4 avant imola yellow
Sportec remap 320hp / 500nm
Brembo GT-brakes
RS4 suspensions
JDB
Post by JDB » Mon Aug 06, 2007 10:56 am
The car is a beast, looking forward to seeing a vid.
Users browsing this forum: No registered users and 144 guests
