Pics: Hood pins beeing mounted on my RS4. This hurt to watch
The K16 look the same spec as the once I use!!Doug_S2 wrote:please say you can go to the ring in september so we can have a good look at this?
what spec k16s are they?
are you using the stock fuel rail for 900bhp?
The fuel rail is not sufficient for 900hp nor is the intake manifold. Also the RS4 throttle plate is only really good for 600hp. So, you're already pushing the envelope running 750hp on those bits. Loads of backpressure in the intake system. Solution is a larger fuel rail and 2 throttle bodies with 2 custom intake manifolds. Unless you know where to get a 95-100mm throttle body? And of course running speed density with no MAF or 2 MAFs.
Apart, from that the rest will cope to deliver 900hp on race fuel tho !!!
So, I'm looking forward to see his results and hopefully both our cars will be ready for the Ring.
My engine is going in THIS weekend and then another week for building the exhaust. Fingers crossed!!! So, I will be down at yours next weekend. ;o)
CAN'T WAIT to finally drive the fruits of 14 month building (well, mostly waiting for parts tho !!!) ;o)
The K16 will fit all original K04 oil, water etc lines with a bit bending here and there. The difficult part is the actuators because there is very limited space. Also if you don't weld the compressor housing as the Dahlback turbos in the pic earlier you'll end up cutting the subframe for one of the charge pipes. So, the easy way would be getting your K16 compressor housing pre-welded.
Dave you meen something along these linesdodgydave wrote:The K16 look the same spec as the once I use!!Doug_S2 wrote:please say you can go to the ring in september so we can have a good look at this?
Engine
Mangement: Autronic stand-alone ECU
Engine block: Stock
Heads: Euro 2.4 liter V6 ALF code (now converted to mechanical valve actuation)
Crankshaft: Stock
Camshafts: Cat Cams 280’
Connecting Rods: Pauter
Pistons: JE pistons
Turbos: Precision Turbo PTB 300-5032 ball bearing
Intercooling: Custom Kreator Mocy dual core FMIC
MAF: None
Injectors: 800 cc @ 3 bar
Fuel Pressure Regulator: 5.5 bar
Ignition: Autronic Spark Module
Nitrous: Twin wet (fuel & N2O) systems-150 hp Nitrous Express and 200 hp TNT
Compression ratio: ~8:1
Boost (absolute): 3.5-4 bar
Horsepower (without Nitrous): ~800-1000 hp depending on rev limit
Torque (without Nitrous): ~1100 Nm (810 ft-bs)
Horsepower (with Nitrous): 1000+ hp (violent spool difficult to measure on wheel dyno)
Redline: 8,000-10,000 RPM
Drivetrain
Transmission: Stock
Front Differential: Quaife LSD
Center differential: Stock Torsen
Rear differential: Stock
Front halfshafts: Audi 100
Rear halfshafts: Stock
Clutch: Twin spring S2/RS2 race clutch
Flywheel: Single mass Audi S2
On second view I think that I have a lager exhaust housing if the dark coating doesn't just make it just look smaller. I'm on a 8. housing and I think his looks like a 7.Doug_S2 wrote:please say you can go to the ring in september so we can have a good look at this?
But a 7. won't be able to deliver 450hp !!! The 8. does around 400hp+
Forgot to tell you that the rims I bought for my car in the first place did not fit. The MTM Bimoto rims will have to do the trick...
It looked a little like this when we tried them on the back. The brakes in the front are just to big, lol.
Schmidt Revolution VN-Line Radinox. Special ordered with a black center. The olny set of it's kind in existence so far.
-<beep> authority.
http://www.vwaudi-club.no/?s=CarProfile ... ommentarer
The V6 doesn't need this mod as it has double bolts on the bearing caps. And another 4 bolts from the side to stiffen and align the bottom end.okkim wrote:How is the standard engine block going to stand the +700 HP? I know one engine which is going to have "corset" between the oilpan and block so it will not twist and break.
Has anyone cracked the block from the crank side?
I reckon you can drive up to 1000hp with no trouble at all. With different rods though. ;o)
Is this a fact? I know that it has those bolts, but one tuning company is making this "corset" to one engine. They are tuning it for 900 hp. I would like to know that what is the maximum power taken out without any modification to crank or in that area.
That Polish S4 does have a lot of power (+900), is that modified from the crank area?
The polish one drives a stock S4 crank and block !okkim wrote:Is this a fact? I know that it has those bolts, but one tuning company is making this "corset" to one engine. They are tuning it for 900 hp. I would like to know that what is the maximum power taken out without any modification to crank or in that area.
far as I know the polish s4 does not have the corsetokkim wrote:Is this a fact? I know that it has those bolts, but one tuning company is making this "corset" to one engine. They are tuning it for 900 hp. I would like to know that what is the maximum power taken out without any modification to crank or in that area.
- SnowTrooper
the stock rs4 throttle body can support the power levels claimed...
car looks awsome, let me know if you want to sell the old gearbox
Jared @ STaSIS Engineering
2000 s4- two turbos, quattro, lots of kevlar, CF and aluminum, slicks, a welded rear diff, weird paint and about 700 hp
1990 CQ- Bone stock, racks, studded tires = ski car
Sorry, but the old gearbox is 6 feet under because of some heavy mistreatment ...SnowTrooper wrote:...let me know if you want to sell the old gearbox
-<beep> authority.
Users browsing this forum: No registered users and 123 guests
