What is your peak MAF reading?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
S4TAN
RE: Re: RE: Re: RE: Re: RE: What is your peak MAF reading?
Post by S4TAN » Sat Jul 14, 2007 1:00 pm
Just fitted my new MAF.... max reading now 194
Hmmm ... still not ideal; should be between 210 and 220g/s for a healthy stock S4.
Deus ex machina
AdamS4
Post by AdamS4 » Sat Jul 14, 2007 1:14 pm
Possible boost leak somewhere ?
Check my post in the Vag-com section, i got a new fault come up
Also, whats the std boost in mbar ? My max reading was 1540
shineydave
Post by shineydave » Sat Jul 14, 2007 1:32 pm
i thinks it's 0.8bar so as Vag-com records the ambient pressure of the atmosphere as well it should read around 1800mbar for a standard car
Dave
AdamS4
Post by AdamS4 » Sun Jul 15, 2007 6:44 pm
Finally, a proper MAF peak reading....
234.61
Which is about 293bhp !!!.... Is that right for a std car !? :shock:
S4TAN
Post by S4TAN » Sun Jul 15, 2007 6:54 pm
234.61
Dude - that's DAMN good for a stock car .... are you sure it's stock???
Deus ex machina
AdamS4
Post by AdamS4 » Sun Jul 15, 2007 7:36 pm
Yeah, AFAIK and from the history i have (right back to purchased new)
Max actual boost reading was 0.85 bar.... Max requested boost reading was 1.05 bar
DavidT
Post by DavidT » Sun Jul 15, 2007 7:50 pm
It's too high mate. Standard car should flow 213 !
Blue_Thunder
Post by Blue_Thunder » Sun Jul 15, 2007 8:13 pm
New peak reading of 326 since my trip to Doug on Friday.
:FIREdevil:
s4sean
My MAF
Post by s4sean » Sun Jul 15, 2007 8:18 pm
Umm.. interesting stuff.
I took a max MAF on mine of 233.5
Mine is standard, AFAIK and according to QST who serviced it.
So is my MAF screwy?
But what's the % range for power as standard on this car?
If 10% then just a good one.
My boost readings all standard, requested 0.8 above ambient, acheived 0.8...
Quess I need to FATS test too.
Will try tomorrow.
AdamS4
Post by AdamS4 » Sun Jul 15, 2007 8:53 pm
DavidT wrote:It's too high mate. Standard car should flow 213 !
So whats that mean ? I just fitted brand new MAF. Boost is normal. No fault codes :?
I got some FATS here... http://www.rs246.com/index.php?name=PNp ... ic&t=62874
DavidT
Post by DavidT » Sun Jul 15, 2007 9:06 pm
Belongs in another thread really.
AdamS4
Post by AdamS4 » Sun Jul 15, 2007 9:51 pm
DavidT wrote:Belongs in another thread really.
Post in this one http://www.rs246.com/index.php?name=PNp ... ic&t=62874
yorkie
Post by yorkie » Thu Jul 19, 2007 6:24 pm
Got 227.75 today on a std car as far as I know.
Also got peak boost of .9 bar and peak requested (never seen before I might add) of 1.02 bar!
That was on my first run before I guess heat soak from hanging around for a clear road took over.
Still manged 223 and peak boost of .83 bar iirc (laptop off at the mo).
I wonder if the current atmospheric conditions are having some effect on air pressure.
Ads4
Post by Ads4 » Tue Jul 24, 2007 7:18 pm
Picked the car up with the Mr.C 400 treatment and reading 335. Awesome. 8)
Adam.
MRC B5 S4 Avant.
GrimReaper
Post by GrimReaper » Thu Jul 26, 2007 4:35 pm
275 from my KO3's
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
