F-Hose delete
- tdiquattro
F-Hose delete
Chaps,
Been thinking about this for a while, would this work?...
[img]modules/pnCPG/Coppermine/albums/userpics/10567/F-hose%20delete.jpg[/img]
Would it affect the operation of the N249?, if not isn't it a very simple solution.
The bleeder valve assembly is already there, just behind the F-hose, just needs relocating, the f-hose feed pipe just needs cutting off and replacing with a short section of pipe, and you need a t-piece in the line to the N249, easy.
I plan to get the bits and do it if no-one can see a problem, the VAG front hose to go where the f-hose is now from the later 2001.5 models is
part no. 078 133 784 BG. a suitable T-piece is 044 127 563 A .
What do you think? (would cost less than a Samco F-Hose).
Nige'
2000 silver S4 Saloon
- tdiquattro
- tdiquattro
RE: F-Hose delete
Well no one seems interested but I have done it and all seems fine, total cost 8 euros.
Nige'
RE: F-Hose delete
Yea, I'm interested actually.
Any views on this please?
I'm surprised S4TAN hasn't had a go at this yet...
Clive
RE: F-Hose delete
I'm watching with interest .... but looks like an awkward place to get to in the engine bay (and i've had no trouble with my f-hose since sticking a Samco version in)I'm surprised S4TAN hasn't had a go at this yet...
Deus ex machina
RE: F-Hose delete
Excuse my ignorance but what exactly does the f hose do?
It would seem the number one culprit for turbo failure, how does it cause that?
- tdiquattro
RE: F-Hose delete
Seems fine, it isn't difficult, about a 15 minute job when I have sorted the parts and how to, just remove the y-pipe to give access, cut the hard crinkle hose that feeds to the f-hose (just after the curved bit, leaving a 20mm length of the smooth bit to push the bleed valve on to, move the bleed valve back, and fit a t-piece. The bleed valve fits perfectly over the cut crinkle hose and then you need a reducer from the 10mm end of the bleed valve to the t-piece hoses (8mm ID) I think I have the right VAG hoses sorted, once I have it tidied up I will post a how to.
I have used odd vag hoses at the mo to make the connections, but I have the correct front one on order, part number above.
I cant see why it should be a problem, I will report back after some use.
Nige'
- tdiquattro
RE: F-Hose delete
double post oops
Nige'
- tdiquattro
RE: F-Hose delete
Looking forward to the 'how to'...
Clive
RE: F-Hose delete
looks really easy on the engine in the picture..considering its out the car..
what did you do with the F hose joint at the front of the manifold..
and why dont you do the N249 delete that most have done...
the crinkle type spider hose is a major cause for concern when there brittle..they can split easily and cause boost leaks..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
RE: F-Hose delete
Not another thing on my list to do is it??? Your bills getting bigger and bigger clive!!
Dave.
White MK2 Golf.. Slightly modified
- shineydave
RE: F-Hose delete
sounds like a job for next saturday, book me in about 10 then i can catch the bacon buttie service before it closes
Dave
RE: F-Hose delete
... i have a 'custom' N249 delete ... better than the standard one. (the Earl of Wakefield can bear witness to thatdo the N249 delete that most have done...
Deus ex machina
