F-Hose delete
- tdiquattro
F-Hose delete
Chaps,
Been thinking about this for a while, would this work?...
[img]modules/pnCPG/Coppermine/albums/userpics/10567/F-hose%20delete.jpg[/img]
Would it affect the operation of the N249?, if not isn't it a very simple solution.
The bleeder valve assembly is already there, just behind the F-hose, just needs relocating, the f-hose feed pipe just needs cutting off and replacing with a short section of pipe, and you need a t-piece in the line to the N249, easy.
I plan to get the bits and do it if no-one can see a problem, the VAG front hose to go where the f-hose is now from the later 2001.5 models is
part no. 078 133 784 BG. a suitable T-piece is 044 127 563 A .
What do you think? (would cost less than a Samco F-Hose).
Nige'
2000 silver S4 Saloon
- tdiquattro
- tdiquattro
RE: F-Hose delete
Well no one seems interested but I have done it and all seems fine, total cost 8 euros.
Nige'
RE: F-Hose delete
Yea, I'm interested actually.
Any views on this please?
I'm surprised S4TAN hasn't had a go at this yet...
Clive
RE: F-Hose delete
I'm watching with interest .... but looks like an awkward place to get to in the engine bay (and i've had no trouble with my f-hose since sticking a Samco version in)I'm surprised S4TAN hasn't had a go at this yet...
Deus ex machina
RE: F-Hose delete
Excuse my ignorance but what exactly does the f hose do?
It would seem the number one culprit for turbo failure, how does it cause that?
- tdiquattro
RE: F-Hose delete
Seems fine, it isn't difficult, about a 15 minute job when I have sorted the parts and how to, just remove the y-pipe to give access, cut the hard crinkle hose that feeds to the f-hose (just after the curved bit, leaving a 20mm length of the smooth bit to push the bleed valve on to, move the bleed valve back, and fit a t-piece. The bleed valve fits perfectly over the cut crinkle hose and then you need a reducer from the 10mm end of the bleed valve to the t-piece hoses (8mm ID) I think I have the right VAG hoses sorted, once I have it tidied up I will post a how to.
I have used odd vag hoses at the mo to make the connections, but I have the correct front one on order, part number above.
I cant see why it should be a problem, I will report back after some use.
Nige'
- tdiquattro
RE: F-Hose delete
double post oops
Nige'
- tdiquattro
RE: F-Hose delete
Looking forward to the 'how to'...
Clive
RE: F-Hose delete
looks really easy on the engine in the picture..considering its out the car..
what did you do with the F hose joint at the front of the manifold..
and why dont you do the N249 delete that most have done...
the crinkle type spider hose is a major cause for concern when there brittle..they can split easily and cause boost leaks..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
RE: F-Hose delete
Not another thing on my list to do is it??? Your bills getting bigger and bigger clive!!
Dave.
White MK2 Golf.. Slightly modified
- shineydave
RE: F-Hose delete
sounds like a job for next saturday, book me in about 10 then i can catch the bacon buttie service before it closes
RE: F-Hose delete
... i have a 'custom' N249 delete ... better than the standard one. (the Earl of Wakefield can bear witness to thatdo the N249 delete that most have done...
Deus ex machina
Users browsing this forum: No registered users and 144 guests
