Nodds
I'll second that. I spent absolutely ages, in the thunder and pouring rain, replacing the bulb and it turned out bulb was fine just a loose connectionChipHazzard wrote:It might be worth giving the bulb holder a wiggle as I thought my sidelight bulb had gone and it turned out to be a loose bulb
shineydave wrote:i got a pair of cheap LED bulbs from the local car shoppe, about 8 quid but they're a conventional bayonet whereas the S4 has offset pins. i just filed one off and they work a treat, much closer to the colour of the xenons
Thanks for that i was abit gutted when i couldnt get the led sides because the normal sides look poxy sat next to the xenon heads.UKS4APR1 wrote:You can get LED bulbs in bayonet with offset pins, here's an example from fleabay.........
http://cgi.ebay.co.uk/XENON-5-LED-H6W-4 ... dZViewItem
