This points to the car "Nannying " with the ESP to me.t_urbo wrote:No Difference under the above conditions with regard to the sport button.hanbury wrote:My car was also built April 07 but I can't say I've noticed any of the above in my first 1,000 miles.
One thing I wonder though, is there any difference in sport mode?
Although i have noticed that if you drive the car hard and change up on the rev limiter it hesitates as you hit the gas in the next gear (regardless of the sport button being on or off) but when the ESP is off it does not do it.
So i now drive most of the time with the ESP .
_______________________
07 Model Year RS4
04 996 Turbo S with switchable ecu maps
580 hp on race profile on sunoco GT Plus
550 hp on fast road profile on super unleaded.
Is any ones car a little hesitant at constant revs?
Re: RE: Is any ones car a little hesitant at constant revs?
hertfordshire1
Software update
As promised (sorry it took so long) the paper work for my ecu work states " carried out software updateengine ecu recall 248H".
Steve
Steve
RE: Re: RE: Is any ones car a little hesitant at constant re
I have checked my chasis no: and it's before the upgrade, chasis from : 8e17n906499 are OK they say mine is before this and it's an 07 march build!!!
Any cmments guys?.
Any cmments guys?.
Re: RE: Re: RE: Is any ones car a little hesitant at constan
I am getting rough running cold.audijohn wrote:I have checked my chasis no: and it's before the upgrade, chasis from : 8e17n906499 are OK they say mine is before this and it's an 07 march build!!!
Any comments guys?.
right, Ipswich have come to the rescue AGAIN, ECU upgrade: 24H8A001 is the correct number for this engine and mine is going in next week.
So you know what number to quote now.
I think there is no difference if the ESP is off or fully off in sraight line , but you can feel it on the track or if you try to do some driftt_urbo wrote:
The hesitation goes weather the ESP is partially off or fully off.
Darey ,
06' Sprint blue RS4
On track it needs to be fully off otherwise it will brake for you when you drift.RS4_B7 wrote:I think there is no difference if the ESP is off or fully off in sraight line , but you can feel it on the track or if you try to do some driftt_urbo wrote:
Darey ,
07 Model Year RS4
These what i've noticedt_urbo wrote:On track it needs to be fully off otherwise it will brake for you when you drift.RS4_B7 wrote:I think there is no difference if the ESP is off or fully off in sraight line , but you can feel it on the track or if you try to do some driftt_urbo wrote:
Darey ,
Thanx alot .
06' Sprint blue RS4
