What is your peak MAF reading?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
smurfbus
Post by smurfbus » Thu May 31, 2007 1:41 pm
There are some exceptions. my evotech chip showed 345g/s for s4 maf. I use ecu-x to log and it has no maf limits.
S4TAN
Post by S4TAN » Thu May 31, 2007 1:44 pm
345g/s with vag-com?
evotech chip - is that a tuner/ecu re-map?
Deus ex machina
smurfbus
Post by smurfbus » Thu May 31, 2007 2:10 pm
yep 345 with vag-com at the time. IIRC AMD maps look like evotech maps or so I heard.
S4TAN
Post by S4TAN » Thu May 31, 2007 2:15 pm
thanks - wonder why I'm maxing out vag-com at 335g/s then ...? (maybe a newer s/w version?)
450-470g/s is massive - nice!
Deus ex machina
smurfbus
Post by smurfbus » Thu May 31, 2007 2:23 pm
I don't think you're maxing vag-com. You are maxing your code or sensor.
MarkB
Post by MarkB » Thu May 31, 2007 2:27 pm
smurfbus wrote:yep 345 with vag-com at the time. IIRC AMD maps look like evotech maps or so I heard.
S4TAN, remember I'm getting near 300 with my AMD map ;) Not that the car is giving anywhere near the power that figure leads you to believe
Mark
smurfbus
Post by smurfbus » Thu May 31, 2007 2:29 pm
Just for the record. I have Mihneas code now. Evotech and possibly AMD scale their maf values up.
S4TAN
Post by S4TAN » Thu May 31, 2007 3:47 pm
Aah - I see ...
Deus ex machina
jeffw
Post by jeffw » Thu May 31, 2007 4:28 pm
335 is the maximum that the S4 MAF can measure. Mine hits 335 at 5K and stays there till over 6.2K
S4TAN
Post by S4TAN » Thu May 31, 2007 5:59 pm
Yeah, that's what I was told initially, then someone else told me that it was a limitation of what vag-com could register from the ecu rather than a limitation of the sensor itself ... oh well - whatever ...
Deus ex machina
S4TAN
Post by S4TAN » Thu May 31, 2007 6:07 pm
... which kinda begs the next question: If the S4 MAF sensor maxes out at 335 does this limit the fueling/timing/spec boost that the ECU can request (due to it only ever being able to "see" 335 g/s as the max air mass/flow) ???
Deus ex machina
ZeroK66
Post by ZeroK66 » Fri Jun 01, 2007 12:56 pm
Apparently I max the RS4 MAF sensor :)
smurfbus
Post by smurfbus » Fri Jun 01, 2007 1:39 pm
You max the 490? or vag-com 360?
S2tuner
Trader (Expired)
Post by S2tuner » Fri Jun 01, 2007 7:41 pm
An S4 sensor can't read over 335g/s and vag-com can't read anything over 364.08g/s on any ECU/sensor ;)
smurfbus
Post by smurfbus » Fri Jun 01, 2007 8:37 pm
how high did Franck and Lucas peak their mafs?
Users browsing this forum: No registered users and 70 guests
