USB Vag-com not working
I went to use my Ross-Tech VAG-COM USB cable last night and the cable tests fine on the laptop but refuses to believe it's plugged into the car....This set-up has worked in the past and the only change is upgrading to 704.1
It appears as if there is power supply to the diagnostic port...is there a seperate fuse for the diag port ?
Any other suggestions why this isn't working ?
- ChipHazzard
RE: USB Vag-com not working
Jeff
There is a sepereate fuse for the diagnostic port, I cant remember which one I think it's in the 20's i spotted it over the weekend while looking for the sidelight fuse
If you want to try another lead give me a shout
HTH
Mike
HTH
Mike
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
Cheers Mike, I'll have another look at the fuse panel
- 1st Gear
What kind of interface is it?
Does the LED light up when you plug it into the car?
-Uwe-
-Uwe-
It is a USB lead into a B5 S4. The LED light does not light up when it's plugged in.
If the LED does not light up, the power supply is not working - which means the fuse ChipHazzard was talking about is most likely the issue. FWIW, "USB lead" is not really what Uwe meant - so what does the label on the interface say?
Sebastian @ Ross-Tech.com
- ChipHazzard
Jeff
If you haven't found the fuse it's number 31 and is 15 amps, it also does the reversing lights, cruise control, auto gearbox & interior & exterior mirrors
HTH
Mike
HTH
Mike
FL Noggy S4 Avant
Cheers Mike, might have noticed if I had a auto gearbox then !
It's a key-usb lead. I've quickly checked and I have reversing lights & am able to move the mirrors but no LED on the lead....Not likely to be the fuse if it does control the 12v line for the reversing lights & mirrors.
Any other ideas ?
Any other ideas ?
- ChipHazzard
You could try my lead if you like Jeff i'm not too far from you, drop me a PM if you want
FL Noggy S4 Avant
I had this once. Found that the lead wasn't fully plugged into the car.
Mark
tried it several times and it seems to be plugged in correctly....I've used this cable before as well. Thanks for the offer of your lead Mike but I'm over at MRC on Saturday so I should be able to test lead & car there.
- ChipHazzard
No probs Jeff
FL Noggy S4 Avant
OK...so Doug's lead works but mine doesn't (even with Doug plugging it in). Looks like the lead is faulty.
- 1st Gear
Re: RE: USB Vag-com not working
Where / when did you buy it? E-mail us with the particulars. Note, Monday is a holiday here in the USA.jeffw wrote:OK...so Doug's lead works but mine doesn't (even with Doug plugging it in). Looks like the lead is faulty.
-Uwe-
Users browsing this forum: No registered users and 31 guests
