USB Vag-com not working
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
jeffw
Post by jeffw » Mon May 21, 2007 1:06 pm
I went to use my Ross-Tech VAG-COM USB cable last night and the cable tests fine on the laptop but refuses to believe it's plugged into the car....This set-up has worked in the past and the only change is upgrading to 704.1
It appears as if there is power supply to the diagnostic port...is there a seperate fuse for the diag port ?
Any other suggestions why this isn't working ?
ChipHazzard
RE: USB Vag-com not working
Post by ChipHazzard » Mon May 21, 2007 1:16 pm
Jeff
There is a sepereate fuse for the diagnostic port, I cant remember which one I think it's in the 20's i spotted it over the weekend while looking for the sidelight fuse
If you want to try another lead give me a shout
HTH
Mike
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
jeffw
Post by jeffw » Mon May 21, 2007 2:07 pm
Cheers Mike, I'll have another look at the fuse panel
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Mon May 21, 2007 3:00 pm
What kind of interface is it?
Does the LED light up when you plug it into the car?
-Uwe-
jeffw
Post by jeffw » Mon May 21, 2007 3:06 pm
It is a USB lead into a B5 S4. The LED light does not light up when it's plugged in.
Sebastian
Post by Sebastian » Mon May 21, 2007 10:01 pm
If the LED does not light up, the power supply is not working - which means the fuse ChipHazzard was talking about is most likely the issue. FWIW, "USB lead" is not really what Uwe meant - so what does the label on the interface say?
Sebastian @ Ross-Tech.com
ChipHazzard
Post by ChipHazzard » Mon May 21, 2007 10:42 pm
Jeff
If you haven't found the fuse it's number 31 and is 15 amps, it also does the reversing lights, cruise control, auto gearbox & interior & exterior mirrors
HTH
Mike
FL Noggy S4 Avant
jeffw
Post by jeffw » Tue May 22, 2007 5:52 am
Cheers Mike, might have noticed if I had a auto gearbox then !
jeffw
Post by jeffw » Tue May 22, 2007 8:36 am
It's a key-usb lead. I've quickly checked and I have reversing lights & am able to move the mirrors but no LED on the lead....Not likely to be the fuse if it does control the 12v line for the reversing lights & mirrors.
Any other ideas ?
ChipHazzard
Post by ChipHazzard » Tue May 22, 2007 9:04 am
You could try my lead if you like Jeff i'm not too far from you, drop me a PM if you want
FL Noggy S4 Avant
MarkB
Post by MarkB » Tue May 22, 2007 9:09 am
I had this once. Found that the lead wasn't fully plugged into the car.
Mark
jeffw
Post by jeffw » Tue May 22, 2007 9:39 am
tried it several times and it seems to be plugged in correctly....I've used this cable before as well. Thanks for the offer of your lead Mike but I'm over at MRC on Saturday so I should be able to test lead & car there.
ChipHazzard
Post by ChipHazzard » Tue May 22, 2007 10:08 am
No probs Jeff
FL Noggy S4 Avant
jeffw
Post by jeffw » Sun May 27, 2007 9:19 am
OK...so Doug's lead works but mine doesn't (even with Doug plugging it in). Looks like the lead is faulty.
Uwe@Ross-Tech
Re: RE: USB Vag-com not working
Post by Uwe@Ross-Tech » Sun May 27, 2007 4:30 pm
jeffw wrote:OK...so Doug's lead works but mine doesn't (even with Doug plugging it in). Looks like the lead is faulty.
Where / when did you buy it? E-mail us with the particulars. Note, Monday is a holiday here in the USA.
-Uwe-
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 44 guests
