Order of modifications
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
optionclick
Post by optionclick » Thu May 03, 2007 3:48 pm
I'm picking up my S4 in a few days. It won't be very long before I'll be paying MRC a visit for a health check etc...
I'm planning to modify the car, and was wondering what my priorities should be. I was thinking along the lines of:
1) Health check.
2) Short shift.
3) Air intake
4) Exhaust (incl decat and gut precats).
5) Remap.
6) Suspension.
7) Brakes.
Does this sound about right?
ChipHazzard
RE: Order of modifications
Post by ChipHazzard » Thu May 03, 2007 3:51 pm
I'd move the brakes further up the list if I was you
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
saf
Post by saf » Thu May 03, 2007 4:00 pm
I second that
Or your car will be eating discs and pads frequently.
DavidT
Post by DavidT » Thu May 03, 2007 4:02 pm
Air intake is pretty much a waste of time too.
Suspension will make a huge difference and would be my number 2 after healtcheck.
GrimReaper
Post by GrimReaper » Thu May 03, 2007 4:09 pm
As already said move the brakes up the list and depending on what type of suspension you go for, think about uprated ARB's as well as it'll stop the wallowing around corners
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
ChipHazzard
Post by ChipHazzard » Thu May 03, 2007 4:17 pm
My order of things is looking like
1. Health Check & Remap (done)
2. Brakes (done)
3. Suspension & ARB's
4. Exhaust & Downpipes
5. Short Shift
6. Snub Mount
Although 3, 4, 5 & 6 might take place ina different order depending on when I manage to find time to fit them all as I have the bits ready to go, I just need to find the time
FL Noggy S4 Avant
optionclick
Post by optionclick » Thu May 03, 2007 4:21 pm
that's interesting. Would you not need another remap afer doing the exhaust & downpipes?
pssst, what's a snub mount? :oops:
ChipHazzard
Post by ChipHazzard » Thu May 03, 2007 4:29 pm
I will probably get another health check done when I get the DP's & exhaust fitted so there might be a bit of tweaking done at the time.
The snub mount stop's the engine rocking back & forth to much when giving it loads and is at the front of the engine. I'm sure someone else will correct my description if I'm wrong
FL Noggy S4 Avant
S4TAN
Post by S4TAN » Thu May 03, 2007 4:43 pm
Wouldn't bother with the air-intake if you mean an induction kit - too much heat under the hood; you'll just be sucking in very hot air and compromise your IATs ... just get a decent after-market panel filter, or stick with the stock paper one (you can drill the bottom of your air-box out though!)
As other have said above: definitely do the suspension, ARBs and brakes next after your exhaust & remap (exhaust before remap)
If you're going for an MRC remap then the health check is part of it (they won't map your car until the health check is done and any leaks/duff DVs/duff hoses are found and fixed)
Put the money you save by not buying the air-intake towards a DTS (drive train stabiliser) - especially if you're getting a shortshifter (they work great together)
A snub mount is a hard compound bung-type-thingy that sits at the front of your engine right at the bottom and butts up against the front of the chassis - it acts as a buffer against any engine movement in the direction of travel due to momentum/braking/gear changing etc... (I assume you mean a poly snub mount as opposed to the stock rubber one - the poly version is harder and more durable than the OEM one)
Deus ex machina
DavidT
Post by DavidT » Thu May 03, 2007 4:47 pm
Ads4
Post by Ads4 » Thu May 03, 2007 4:48 pm
Haven't done my brakes yet!! Had a remap, Milltek full system, then fitted s/s, H&R coilovers and NEXT are the brakes!!
I have always been a champion of the standard brakes as, having never been on the track, I've never had a bad fade moment. I did, however, have a bad fade moment the other day, on the road following some spirited driving, thus they are my next mod!!
Adam.
MRC B5 S4 Avant.
S4TAN
Post by S4TAN » Thu May 03, 2007 4:52 pm
:lol: A similar type of event caused me to have a major re-think about sticking with my stock brakes: a serious "brown trouser moment" made me get some RS6 brakes installed quick-sharp ...!
Deus ex machina
Ads4
Post by Ads4 » Thu May 03, 2007 4:56 pm
The coppers are being counted and the brake fund is rising.. :D
Unfortunately that means the turbo fund is going down again.. :(
Adam.
MRC B5 S4 Avant.
S4TAN
Post by S4TAN » Thu May 03, 2007 5:05 pm
Bummer! :wink:
Deus ex machina
Ads4
Re: RE: Order of modifications
Post by Ads4 » Thu May 03, 2007 5:10 pm
Bummer! :wink:
I'm sure after you've taken me for a spin Julian I'll be saving again with a new ferocity.. :twisted:
Adam.
MRC B5 S4 Avant.
Users browsing this forum: Majestic-12 [Bot] and 77 guests
