Whoops, Redline
markwm
Whoops, Redline
Post by markwm » Tue Apr 24, 2007 9:17 pm
Thought I'd try the sport mode from 1st and before I could tear myself away from the glorious noise I was in the redline!!!
whoops, not even 60 miles on the car yet. I take it I need to be more careful? :oops:
Dom81
RE: Whoops, Redline
Post by Dom81 » Tue Apr 24, 2007 9:34 pm
Funny - did exactly the same yesterday (with virtually identical mileage...)
2007 Daytona RS4 Avant
Adam
RE: Whoops, Redline
Post by Adam » Tue Apr 24, 2007 11:10 pm
I've done it a few times now keeping eyes on road whilst engine revs forever. No harm done as that it what the limiter is there for, just don't miss 5th and get 3rd on a downchange.
flashyg
RE: Whoops, Redline
Post by flashyg » Tue Apr 24, 2007 11:17 pm
Very good for the piston ring seal, especially early on in the cars life.
It is thought that many of the b7,s have been run in too gently causing poor ring seal.
G
Andyuk911
RE: Whoops, Redline
Post by Andyuk911 » Tue Apr 24, 2007 11:24 pm
you need to yoyo , ie slow down from high revs with engine breaking, make for good seal and more power
RS4 Avant - Sold Aug 2009
tartan_rob
RE: Whoops, Redline
Post by tartan_rob » Wed Apr 25, 2007 8:14 am
Just 60 miles on the clock, I assume not from brand new otherwise you'll have invalidated yor warranty?
2017 Kawasaki Z1000
2014 RS6
2014 S1
Andyuk911
Re: RE: Whoops, Redline
Post by Andyuk911 » Wed Apr 25, 2007 8:38 am
Tartan_Rob wrote:Just 60 miles on the clock, I assume not from brand new otherwise you'll have invalidated yor warranty?
Bizare
Jezzer
Post by Jezzer » Wed Apr 25, 2007 8:46 am
How do you mean Rob?
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
tartan_rob
RE: Re: RE: Whoops, Redline
Post by tartan_rob » Wed Apr 25, 2007 8:52 am
I thought all RS4's had a run-in period. If you exceeded 5k revs (or whatever) in the first x miles, you invalidated your warranty.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Adam
Post by Adam » Wed Apr 25, 2007 9:06 am
nonsense
(I hope)
my dealer said "take it easy over the first few hundred miles"
binder
Post by binder » Wed Apr 25, 2007 11:24 am
I was told that if you exceed the running in instructions (7000 rpm max) that the engine management recorded it and it would nullify the warranty.
alex_123_fra
Post by alex_123_fra » Wed Apr 25, 2007 12:47 pm
If the RS4 ECU has data-logging capabilities, you may have problems with warranty although it isn't that simple.
For the benefit of the car, the last thing I would do is follow the manufacturer run-in procedure. The best results are achieved as follows:
http://www.mototuneusa.com/break_in_secrets.htm
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
willbaforce
Post by willbaforce » Wed Apr 25, 2007 2:53 pm
I asked my dealer about run in procedure etc when i collected the car. Was told to just drive the thing but let it warm up properly first. Took it relatively easy for the first 200 miles before pushing up the rev range and changing the oil and filter at 600miles, very important in my opinion if your planning to drive it hard from new.
t_urbo
Post by t_urbo » Thu Apr 26, 2007 8:49 am
alex_123_fra wrote:If the RS4 ECU has data-logging capabilities, you may have problems with warranty although it isn't that simple.
Second that.
The last two 996 turbos i had and this RS4 were run in hard, pretty much as per the link above. i have found that it seriously reduces oil consumption. The RS4 has 1500 miles on the clock now and the oil is still showing just below max.
flashyg
Post by flashyg » Thu Apr 26, 2007 10:43 pm
Sound like the right thing to do.
Every person with a reasonable level of knowledge agrees with the importance of pressing on in the early miles with pulls up the rev range and engine braking.
Good to see your agreement on this.
A good ring seal will definitely keep the oil out of the chamber and protect the oil from dilution of fuel.
G
Users browsing this forum: Bing [Bot] and 147 guests
