whoops, not even 60 miles on the car yet. I take it I need to be more careful?
Whoops, Redline
Whoops, Redline
Thought I'd try the sport mode from 1st and before I could tear myself away from the glorious noise I was in the redline!!!
RE: Whoops, Redline
Funny - did exactly the same yesterday (with virtually identical mileage...)
2007 Daytona RS4 Avant
RE: Whoops, Redline
I've done it a few times now keeping eyes on road whilst engine revs forever. No harm done as that it what the limiter is there for, just don't miss 5th and get 3rd on a downchange.
RE: Whoops, Redline
Very good for the piston ring seal, especially early on in the cars life.
It is thought that many of the b7,s have been run in too gently causing poor ring seal.
G
G
RE: Whoops, Redline
you need to yoyo , ie slow down from high revs with engine breaking, make for good seal and more power
RS4 Avant - Sold Aug 2009
tartan_rob
RE: Whoops, Redline
Just 60 miles on the clock, I assume not from brand new otherwise you'll have invalidated yor warranty?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Re: RE: Whoops, Redline
BizareTartan_Rob wrote:Just 60 miles on the clock, I assume not from brand new otherwise you'll have invalidated yor warranty?
How do you mean Rob?Tartan_Rob wrote:Just 60 miles on the clock, I assume not from brand new otherwise you'll have invalidated yor warranty?
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
tartan_rob
RE: Re: RE: Whoops, Redline
I thought all RS4's had a run-in period. If you exceeded 5k revs (or whatever) in the first x miles, you invalidated your warranty.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
nonsense
(I hope)
my dealer said "take it easy over the first few hundred miles"
(I hope)
- alex_123_fra
If the RS4 ECU has data-logging capabilities, you may have problems with warranty although it isn't that simple.
For the benefit of the car, the last thing I would do is follow the manufacturer run-in procedure. The best results are achieved as follows:
http://www.mototuneusa.com/break_in_secrets.htm
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
willbaforce
I asked my dealer about run in procedure etc when i collected the car. Was told to just drive the thing but let it warm up properly first. Took it relatively easy for the first 200 miles before pushing up the rev range and changing the oil and filter at 600miles, very important in my opinion if your planning to drive it hard from new.
Second that.alex_123_fra wrote:If the RS4 ECU has data-logging capabilities, you may have problems with warranty although it isn't that simple.
The last two 996 turbos i had and this RS4 were run in hard, pretty much as per the link above. i have found that it seriously reduces oil consumption. The RS4 has 1500 miles on the clock now and the oil is still showing just below max.
Sound like the right thing to do.
Every person with a reasonable level of knowledge agrees with the importance of pressing on in the early miles with pulls up the rev range and engine braking.
Good to see your agreement on this.
A good ring seal will definitely keep the oil out of the chamber and protect the oil from dilution of fuel.
G
G
Users browsing this forum: Google [Bot] and 1036 guests
