S4 and bendy wheels
optionclick
S4 and bendy wheels
Hi there,
I've been doing a fair bit of reading up on S4/RS4's with a view to buying soon. I've decided to go for an S4, but am slightly concerned with the 'bendy wheels' topics relating to the RS4.
Does the S4 suffer from the same problem?
thanks in advance
thanks in advance
RE: S4 and bendy wheels
No, the S4 ones are pretty strong. They are 7.5 x 17 and run 45 series tyre as standard, compared to the RS4 with 8.5 x 18 on 35 series tyres - big difference.
I seem to have amassed a garage full of wheels if you ever need one
optionclick
Thanks David, that's good to know.
All I need to do now is find a good one (Nogaro Blue, black leather <40,000miles)
Good luck! Be interesting to see if you get that or which of those two you comprimise on.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
optionclick
hopefully found one already
just need to view/drive it.
For clarification, apparently the bending of the RS4 Avus wheels was intentional for safety reasons. After a LOT of intervention by RS4 owners they got a lifetime warranty on them and then Audi introduced a less bendy version. So as David states, this did not affect the S4 at all.
The S4 has its own problems so I suggest you do a lot of reading here - everything you need to know is on this site!
2001 Silver S4 Avant
optionclick
Definitely - I'm compiling a checklist this week.
Glad to be able to dismiss the wheel issue.
Re: RE: S4 and bendy wheels
In all seriousness David how many do you have? If the answer is somewhere on the site then I apologise beforehand as I haven't done a search.DavidT wrote:No, the S4 ones are pretty strong. They are 7.5 x 17 and run 45 series tyre as standard, compared to the RS4 with 8.5 x 18 on 35 series tyres - big difference.
RE: Re: RE: S4 and bendy wheels
I have 11 18" wheels, 4 original rs4 reps, 4 new rs4 reps and 3 Boss XTRs (one met with an unfortunate death caused by a granite curbstone being in the middle of the road).
I think around 15 mate
