Well, they're finally on ..............
- alex_123_fra
It is definitely an addiction (modding)...know exactly what you mean. I couldn't help myself with the M400 either.NotNormal wrote: It's a stock RS4 exhaustI might at a later date get the Miltek down pipe's but i'll keep with the std system, don't wanna get to the evo loudness
The remap can wait TBH, can't be doing with the agro![]()
As for suspension, i have a friend (that you also know) that has a frien that can supply Koni coilovers .......... inafew months we shall see .
What happenedto my "i'll leave this one std, i'll not touch it apart from the brakes" hey !!!!
I've vowed to leave the RS4 standard but I just know the minute I get it I'll want a miltek.
You must put up some pics of it with the coilovers when you get them done....and the supercharger
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
philipwalker
- 5th Gear
Not sure I would change the suspention if using the car as a daily drive.
The ride and handling is very good standard far better than a standard older 2.7 S4. I have fitted a pair of H+R B7 RS4 roll bars to my V8 S4 very good much improved. Along with a decent set of BBS Lms to house the direct fit RS4 brakes.
I might try that then, as i'm happy enough with the ride height.philipwalker wrote:Not sure I would change the suspention if using the car as a daily drive.
dunno, we'll see how the funds are going
A quick question (mostly aimed at Corey) about wheel spacers.
I've also always thought the S4 looked a little narrow in it's stance, could this be adjusted easily by just using spacers and keping the standard Avus alloy? Are there any downside to this? Extra strain on the wheel bearing maybe? What about the difference in length to the hub threads - surely the bold has 15mm less thread to grip onto?
Corey's away this week, but, i have the 10 mm spacer fitted(hubcentric) and the stance of the car is superb. They come with the correct size wheel bolts ect......
As for adverse effects, no problems to report but i can't see it putting too much strain on the bearings ect...; if they did they'd not sell any as people would get anoyed at replacing worn out parts before their time.
philipwalker
- 5th Gear
As above
You could fit a hub center 10mm spacer, say Eibach or H+R . Generally any spacer less than 10mm does not have the center lip for the wheel to mount on.
It should not put any extra loading in the components, it would be the same a lower et number wider wheel.
Ring or PM me if you need a set.
Philip
01437 563793
Philip
01437 563793
ship_broker
Sorry to dig up such an old thread folks but i have a question about the spacers Not Normal used.
I bought some Eibach 8mm spacers for my B6 S4 and found that as they don't have the collar i couldn't get them to seat quite how i wanted and found i got vibrations when into three figures. I resolved this by getting 5mm spacers but i'm not happy with the look they give and am now thinking that 10mm spacers are the way forward, provided they have a collar to seat the wheel on.
Can anyone advise?
James
Can anyone advise?
James
- Virdee Autos
- Trader (Expired)
I don't think you'll find 5/6mm hubcentric spacers.....the hubcentric part is the collar.
I think 10mm will be the minimum. Or at least H&R supply 10mm hubcentric spacers.
Virdee Autos ~ 07950-526592
- Virdee Autos
- Trader (Expired)
Looking at MTM spacers on the website, they seem to be very very similar to the H&R items if not the same
