Samco TBB bad mould??
Got a new Samco TBB the other day. I've heard the moulds aren't the greatest but I think this is taking that too far...
My pressure sensor sits at an angle but not this far over and theres not much space to fit a clip. I take it this isn't normal? Should I send it back?
- Attachments
- IMAGE_00003.jpg (28.03 KiB) Viewed 1184 times
- IMAGE_00002.jpg (25.99 KiB) Viewed 1184 times
- IMAGE_00001.jpg (24.62 KiB) Viewed 1184 times
Mark
RE: Samco TBB bad mould??
Looks like they have improved it to me!
Getting a lip to fit is another matter.
Looks pretty similar to mine Mark - i trimmed part of the top of the pressure sensor opening to make it a little flatter ...
Deus ex machina
The ribs inside the sensor take off are parallel with the end... It's quite a severe angle
Mark
Does it have samco stamped on it anywhere? I'm pretty sure mine did and although it sat quite high, was not offset like that!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
looks like a pair of rubber pants for a midget gimp..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Re: RE: Samco TBB bad mould??
You want them? Dress to the left Sir?s4woody wrote:looks like a pair of rubber pants for a midget gimp..
Mark
RE: Re: RE: Samco TBB bad mould??
HEY! That's my line ...!looks like a pair of rubber pants for a midget gimp..
Deus ex machina
ha ha..you was to busy rubbing vasaline into your worn out gimp pants...sorry mark..back on topic now i think...
020 83353032
020 83353032
Mine was exactly like that, if you look at the original one it sits at an angle too.
Tried in vain to find a clip and ended up using a tie wrap which seems to work ok.
You won't be able to re-fit the engine cover either unless you "relieve" it.
Damn it! You've been spying on me again .....grrrrr!ha ha..you was to busy rubbing vasaline into your worn out gimp pants
Back on-topic: I managed to get a clip that was just right for the sensor opening ... but as yorkie says: the engine cover doesn't clip back down at the top corner ... trimming the opening can cure this a little...
Deus ex machina
Totally normal mark! Mine is exactly the same. Makes the engine cover pop off all the time
Wide Body S4
I'm not sure the photo shows just how bad the angle is. Looks quite different to the one in pictures on GrahamS4's gallery.
I also looked at the one fitted on JimboGrey's car and his sits level.
I'm getting it replaced anyways... see what the next one looks like!
Mark
