RS6 front brakes onto RS4 B5
2.7 V6 30v biturbo - 380 bhp
okkim
Post by okkim » Tue Mar 27, 2007 1:13 pm
I guess no one here has a measuring tool? ;)
Nige_RS4
Post by Nige_RS4 » Tue Mar 27, 2007 5:34 pm
I've just gone out and bought one - I measured 2567854678 microns!
Actually, I measured around 24mm, that's with new pads (less than 2k miles)
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
derdle
Post by derdle » Tue Mar 27, 2007 6:50 pm
ask the user on the forum that removed the movits and replaced with rs6 setup
Thanks Doug!!
Hi Ash,
I had the Movit 4 pot setup on my RS4 with 380x32 discs. The brakes can only be described as stonking. They hauled the car up from phenomenal speeds very quickly....made my eyes bleed.
But as you may have guessed there was a downside. The first set of discs lasted about 9000 miles before cracking and failing an MoT. They also suffered severe vibration.
The second set of discs lasted about 6000 miles before the inner surfaces wore out. The outer faces were perfect..the inner surfaces shot. I decided that I'd prefer the more cost effective option of the RS6+ setup compared with the regular replacement of the Movit discs and also I could get replacement pads very easily from VAG Parts, MRC or my local stealership.
For me the choice was one based on cost. If money was not considered then the Movits provide more braking power.
HTH
Paul
blackb1ade
Post by blackb1ade » Thu Mar 29, 2007 9:57 pm
Cheers Derdle
I just want better brakes than it has as OE (which are very unimpressive I have to say) - it would be really nice to have the movits, given they sound phenomenal, but does dsound a little excessive (although I am a low mileage driver, prob <5k pa so wouldnt be too bad)
So, the B7/rs6 setup got fitted today by Kim collins and he's finishing the st3 MTM tommorrow.... :twisted: I hope the M23/M25 isn't TOO congested tommorrow afternoon
must excercise restraint....must exercise restraint..... :lol:
(actually, on that, will I have to uprate the clutch for the st3 extra horses? or not neccessarily? I know I did have to in my 1.8Tsport as it couldn't deal with the st2 torque - which cost an extra 1300 quid because it was the 5 speed box ) :(
philipwalker
Post by philipwalker » Thu Mar 29, 2007 10:11 pm
RS4/6 Calipers are now £453.68. Pads are £244.08 as of todays price upload
http://www.pwmotorsport.com
PW Motorsport
01437 563929
okkim
Post by okkim » Fri Mar 30, 2007 8:17 am
Nige, how did you measured it? I got those also yesterday, and the thickness is 61 mm with a new pads. (from the pad surface to the calipers top.
That it too much for my wheels, I probably have to sell them if I can't make enough space for them by removing material from here and there...
Does anyone have any idea how much could I take off from the caliper's surface without braking it?
Nige_RS4
Post by Nige_RS4 » Fri Mar 30, 2007 9:21 am
Okkim, you could consider fitting a small 3mm spacer?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
okkim
Post by okkim » Fri Mar 30, 2007 9:49 am
I think not, the wheel is 10" wide and ET10, it is already right on the edge.
MarkB
Post by MarkB » Fri Mar 30, 2007 10:08 am
okkim wrote:I think not, the wheel is 10" wide and ET10, it is already right on the edge.
Which disc have you got?
Mark
okkim
Post by okkim » Fri Mar 30, 2007 10:42 am
It is the B7 RS4 disc. I have been wondering, that could it be possible to change it's offset somehow. It might be possible because it is floating.
MarkB
Post by MarkB » Fri Mar 30, 2007 10:48 am
The RS6 disc will move the caliper in slightly. May be worth looking at?
Mark
okkim
Post by okkim » Fri Mar 30, 2007 10:58 am
But the caliper is bolted straight to the that thing what name I don't know in english ;) ? Does it need spacers then? I would like to keep those B7 discs because I think that they are better. Well, in next week I know what I have to do.
MarkB
Post by MarkB » Fri Mar 30, 2007 11:08 am
To use the RS6 disc you need a caliper bracket to mount to the 'upright' and change the offset
The RS6+ disc's aren't bad. They aren't truly floating but they have curved vanes and are handed unlike the B7 RS4 disc
Mark
okkim
Post by okkim » Wed Apr 04, 2007 6:15 pm
Now I have tested the brake and wheel clearance. It needs a 22 mm spacer, then the wheel won't touch to caliper. :( And then the wheel is about 25 mm outside the fender.
I could move the disk and caliper 10 mm inwards, but that is not enough. Damn.
Nige_RS4
Post by Nige_RS4 » Wed Apr 04, 2007 6:48 pm
What wheels have you got to give you such a huge problem??
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
