How light is a lightened flywheel?
tanoga
Re: How light is a lightened flywheel?
Post by tanoga » Mon Jun 09, 2003 7:10 am
i like the smooth, quiet approach
get an S8 then [img]images/graemlins/biggrin3.gif[/img]
tanoga
Post by tanoga » Mon Jun 09, 2003 7:19 am
Another side effect of a lighter flywheel is normally a lumpier tickover (less mass to keep the engine rotating).
Sometimes it may also mean the engine will stall when dipping the clutch from higher revs. This is normaly overcome by increasing the tickover slightly.
BTW, dual-mass flywheels are standard on most of the porsche range too, except the RS. People changing to the RS flywheel generally experience the above, unless they raise the tickover.
Cheers,
John.
There are none of the above issues with my car.
Any prospective "Tanoga light weight flywheel purchaser" who wish to have a test drive before they buy post here and I will oblige.
JohnW
Post by JohnW » Mon Jun 09, 2003 7:44 am
Hmm, interesting [img]images/graemlins/wink.gif[/img]
I can't rememberthe difference in weight for the porsche RS flywheel compared to standard. Maybe the problems they have is more to do with the engine layout (flat6) and the v6 is just that much smoother that its not a problem...
So, what would one of these flywheels of your set me back ? (supply only)
Cheers,
John.
Too many toys, not enough time
Prawn
Post by Prawn » Mon Jun 09, 2003 9:07 am
I assume that with the K04's fitted and the standard flywheel there would be just a bit more lag than with the K03's?? maybe 500rpm later pickup. Would this be realistic do you think? [img]images/graemlins/062802beat_prv.gif[/img]
I would have to say no to this, no perceptable change in the lag IMO
Not the case either, the ECU seems more than capable of countering this, certainley in my case tickover is as smooth as pre flywheel.
Prawn
Joshie
Post by Joshie » Mon Jun 09, 2003 10:39 am
Just catching up with this post after a trip.
As Prawn said there is a slight metallic rattle below 2K revs but I must admit that I don't allow the revs to drop this low anymore, rather using a lower gear than normal means that I never hear this noise which, I have to say, is not intrusive anyway. And I would say that accelerating from 1200-1500 RPM in a higher gear is not that good for the engine anyhow.
I have not experienced any shudder, vibrations within the car or any other negative effects - it's one of the best mods I have done.
Dippy
Post by Dippy » Mon Jun 09, 2003 12:47 pm
Thanks Karl [img]images/graemlins/thumb.gif[/img]
2001 Silver S4 Avant
RobK
Post by RobK » Tue Jun 10, 2003 3:52 pm
Joshie, has your car got one of the lightwieght ones in then? I noticed at Castle Combe it made a metallic rattling noise when you floored it.
Joshie
Post by Joshie » Tue Jun 10, 2003 8:45 pm
Hi Rob,
Yes it does and it was fitted before Castle Combe. Did you hear it as I moved off along the slip road to the track?
Otherwise as I said I hardly notice it as I am rarely below 2000 rpm. For anyone interested in this mod I'd be happy to demonstrate at the next meet.
RobK
Post by RobK » Tue Jun 10, 2003 9:48 pm
It was just as you went past on the track. Have a look at this vid to see what I mean (it's 2 meg). I thought it was your exhaust or something.
Joshie
Post by Joshie » Tue Jun 10, 2003 10:29 pm
Thanks Rob and yes, I hear what you mean. Curious [img]images/graemlins/confused.gif[/img]
I must say that there is no noise whatsoever now above 2K RPM and if anyone has any theories I'd like to hear them!
wazza
Post by wazza » Wed Jun 11, 2003 11:34 am
Rob usually uses the DivX codec. I'm sure he will post where to get it from. [img]images/graemlins/thumbs.gif[/img]
Paul
RobK
Post by RobK » Wed Jun 11, 2003 1:38 pm
Actually that was mpeg format with mp3 audio I believe. Should play in media player, I don't think there's a particular codec you need.
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Jun 22, 2003 11:43 am
Can anyone give me a cost on a lightweight fly wheel and where to where to buy it from. Will be fitting a new clutch to my s4 soon.
thanks
brett [img]images/graemlins/confused.gif[/img]
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
