Don't ignore your tyre pressure warning
Andyuk911
Post by Andyuk911 » Mon Mar 19, 2007 11:03 am
Well., started the car and bing bong tyre pressure warning .... check round the car and all seemed in order ... out with the guage ... left rear 5lbs down ... so as I rolled slowing bcakwards my son spots a screw dead centre in the tyre.
Off to Kwick Fit on Sunday 2.00pm ...
Point to note .. Monitor ...
Oh and this was free ??
RS4 Avant - Sold Aug 2009
Golich
RE: Don
Post by Golich » Mon Mar 19, 2007 1:51 pm
Yes the pressure monitors are a great idea. Over the years with ultra low profile tyres I've found on occasion my tyre pressures to be low but all looked ok. You like to know about low presssure before you pounce into a corner!!!
OOo that sprint blue looks bonny...
Why does that colour look so bloody different on other models so much so that I didn't want to take the risk when ordering my RS4 and I went for the safer bet - Red. Mind you, the order form still has sprint blue and the salesman hasn't replied to my email querying the colour? Lucky dip!
bobjebb
Re: RE: Don
Post by bobjebb » Mon Mar 19, 2007 2:19 pm
Golich wrote:Lucky dip!
...As long as you dont get half and half...
So was that tyre repaired OK?
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
hugy
Post by hugy » Mon Mar 19, 2007 2:21 pm
Hi Andy911.
Did they scratch the alloy wheel while working on it.I find tyre centres in general are a little careless unless you stand over them,watching.I am thinking of buying a set of BBS CK wheels in anthracite finish.Do you know if I can use my original tyre pressure sensors?
Andyuk911
Post by Andyuk911 » Mon Mar 19, 2007 2:47 pm
hugy,
they were careful .. however the correct procedure is this with tape ..
The TM should work ok, whatever the alloy
david7m
Post by david7m » Mon Mar 19, 2007 2:56 pm
Does that tape not get trapped?
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
SimonS4MTM
Post by SimonS4MTM » Mon Mar 19, 2007 3:02 pm
hugy wrote:Do you know if I can use my original tyre pressure sensors?
You may need different valves to mount the sensors on unless the wheel profile is similar.
The sensor bolts to the back of the valve and there are different valves for different wheels. The valves come in different lengths and fixing holes at different angles to suit most wheel types.
GlynRS2
Post by GlynRS2 » Tue Mar 20, 2007 7:59 am
How annoying is that!
Glad that the pressure sensors work well though.
Glyn
Navarra Blue RS6 Vorsprung (C8)
Sepang Blue RS6 Performance (C7) - sold
Sepang Blue S5 sportback (B8.5)- sold
Monza Silver RS6 (C6) - sold
Sprint Blue RS4 (B7) - sold
Polar Silver RS2 (B4) - sold
hugy
Post by hugy » Tue Mar 20, 2007 1:47 pm
Thanks andy 911.I have just found out the bbs ck wheels will not fit!
simple1
Post by simple1 » Tue Mar 20, 2007 8:55 pm
Mine bing bong from time to time, check them anf there is no drop in pressure, turns out to be part of the dis fault for which my dash was changed along with low oil warning.
SteveH
Post by SteveH » Tue Mar 20, 2007 10:05 pm
I've never seen anyone use tape like that Vauxhall alloy picture... I'm paranoid that my spotless alloys will get buggered when I get new rears next month :cry: Sadly, I'd pay say an extra £20 for extra time care and attention spent on each alloy.
Present:...
Past:
andypandy
Post by andypandy » Wed Mar 21, 2007 11:11 am
what are the tyre pressures on the rs4 b7,mine has no sticker
simple1
Post by simple1 » Wed Mar 21, 2007 3:18 pm
I run mine at 36 front and 33 rear, not sure how that compares to recommended but seems to suit my car and driving style.
Mikeyboy
Post by Mikeyboy » Thu Mar 22, 2007 2:08 pm
supposed to be 38 and 35 for the 19" wheels. any less will give you decent frip once warmed up but will be running about 10% less efficietly at Simple's pressures
simple1
Post by simple1 » Thu Mar 22, 2007 9:49 pm
run them at 38 and 35 and you will have damaged tyres, wheels and sore back on the country roads I use........... my car works fine at those pressures, but its a personal choice for the feeling and feedback the car gives.
Users browsing this forum: Google [Bot] and 236 guests
