5bar FPR
MarkB
5bar FPR
Post by MarkB » Wed Mar 14, 2007 11:48 am
Is raising the fuel pressure an acceptable way of getting more out of stock injectors?
Would it cause issues with mapping? (custom remap)
Mark
JonnyX
RE: 5bar FPR
Post by JonnyX » Wed Mar 14, 2007 2:11 pm
You would get more out of your injectors (and probably better atomisation)
but you still need a fuel pump that can meet the flow rate and rail pressure.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
MarkB
RE: 5bar FPR
Post by MarkB » Wed Mar 14, 2007 2:17 pm
So a better pump and a 5bar FPR could be a good move? If the tuner is happy to work with them
Mark
tartan_rob
RE: 5bar FPR
Post by tartan_rob » Wed Mar 14, 2007 7:21 pm
You need to be careful that the fuel system is upto the extra pressure. The would be my main concern. What is std fuel pressure?
2017 Kawasaki Z1000
2014 RS6
2014 S1
MarkB
RE: 5bar FPR
Post by MarkB » Wed Mar 14, 2007 8:08 pm
4 bar I think
Mark
ZeroK66
RE: 5bar FPR
Post by ZeroK66 » Fri Mar 16, 2007 8:35 pm
I replied to this but my post seems to have vanished?
There must be quite a bit of cost involved in getting this done & also the map would have to be developed from scratch. I think it would be a good idea though... smaller injectors means better atomisation which means potentially better fuel economy... we would all be happy with that. I just think the costs of working on this would out weigh the cost of simply buying injectors?
MCB
RE: 5bar FPR
Post by MCB » Fri Mar 16, 2007 9:47 pm
Could do with Minhea or Doug to add to this however I can't see why this would be a problem. With my limited knowledge stock pump and 5bar FPR should be okay and cant see why MRC Co could not tweak your map to account for this?
S4B5 Avant
JonnyX
RE: 5bar FPR
Post by JonnyX » Fri Mar 16, 2007 9:57 pm
You should actually be able to manually scale this. Get a MAF housing which is 25% bigger for instance.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Users browsing this forum: No registered users and 52 guests
