RS6 front brakes onto RS4 B5
Hi all.
Nearly ran out of road the other day. I've been advised to fit some RS6 front disks and callipers. Whats the best way to go about it?
My local audi specialist said that it can be done but he will need to look into it. Any idea's on costs or a point in the right direction would be much appreciated.
Only had it a week and already thinking 'big'. Missus thinks i'm nuts.
Owen.
Owen.
RE: RS6 front brakes onto RS4 B5
Give Doug a call on 01295 277 308
RS6 Callipers and B7 RS4 Drilled Discs are a good combo. Seen them on a 2001 RS4 Absolutly Massive and loads of stoping power
Wide Body S4
- shineydave
and a doddle to fit, bolt straight on
Dave
RS6 Calipers & pads on std RS4 discs are also excellent, then upgrade to B7 RS4 discs when you need to.
If you're handy with a spanner, then get them from dsgwagen via ebay (mention RS246 and he will give you a discount!).
If you don't fancy getting your hands dirty, then MRC will sort you out!
HTH
HTH
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Re: RE: RS6 front brakes onto RS4 B5
Is that what you've done Nige? I'm thinking the same as a first step... Well, second step, running standard B5 RS4 at the momentNige_RS4 wrote:RS6 Calipers & pads on std RS4 discs are also excellent, then upgrade to B7 RS4 discs when you need to.
HTH
Mark
RE: Re: RE: RS6 front brakes onto RS4 B5
Yep, Doug will vouch for how effective they areIs that what you've done Nige?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
- cpt_splash
I am about to do the very same mod.
APS is Brackley do the whole kit for £1400 + VAT & fitting (2-3 hrs), AmD do their Monster kit for around £1700, VAGPARTS do the RS6 kit for £1280 + VAT. I went to my local main Audi stealer and they wanted, get this, £450 per caliper, plus £206 for RS6 pads, plus £360 per front disc!! Madness, nearly £1900 for the same parts as the specialists.
I am having standard rear discs fitted but will upgrade to the RS6 front. Not sure where to buy yet though. I have seen on ebay front B7 RS4 discs for £474 per pair, so this makes it more cost effective. I also saw both RS6 calipers on the German ebay site for £700.
B5 RS4 - RS6 Calipers/B7 RS4 Discs, H&R ARB's, MRC Custom Remap, RS246 Sticker!! SOLD!!
- quattrosteph
RS6 brakes
MRC did fit some RS6plus set on mine a while ago and the difference is massive.
Give them a call they may offer you a good deal
Porsche 996 Turbo S Atlas Grey.
RS4 B7 Avant Sprint Blue. Sold.
RS4 B5 Avus Silver with MRC magic . Sold (Best car ever )
S4 B6 Avant Nogaro blue. Sold
A6 Avant Silver . 2.5 TDI .Sold
RE: RS6 brakes
RS6 calipers are around £240+VAT at the moment if you shop around!!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
RE: RS6 brakes
Don't forget the RS6 brake pipes if you don't fancy bending the stock RS4 flexi pipes.
I went for the full Brembo RS6 8 pots with RS4 B7 floating vented cross drilled discs. Absolutely fantastic.
I too was considering a halfway house measure of just bolting the new calipers onto my existing B5 discs. It would have worked, but as the discs are smaller there would have been a small amount of the pad running off the discs, which would have meant that, when I upgraded the discs I would have needed a new set of pads as well, so I considered it false economy.
Mike
Q7
Q7
we do the full kit for £1250 inc!
http://www.MRCtuning.com
- cpt_splash
- cpt_splash
Users browsing this forum: No registered users and 120 guests
