RS6 front brakes onto RS4 B5
2.7 V6 30v biturbo - 380 bhp
BigO
Post by BigO » Wed Feb 21, 2007 6:19 pm
Hi all.
Nearly ran out of road the other day. I've been advised to fit some RS6 front disks and callipers. Whats the best way to go about it?
My local audi specialist said that it can be done but he will need to look into it. Any idea's on costs or a point in the right direction would be much appreciated.
Only had it a week and already thinking 'big'. Missus thinks i'm nuts.
Owen.
S2tuner
Trader (Expired)
RE: RS6 front brakes onto RS4 B5
Post by S2tuner » Wed Feb 21, 2007 6:22 pm
Give Doug a call on 01295 277 308 ;)
h8cak
Post by h8cak » Wed Feb 21, 2007 6:53 pm
RS6 Callipers and B7 RS4 Drilled Discs are a good combo. Seen them on a 2001 RS4 Absolutly Massive and loads of stoping power :D
Wide Body S4
shineydave
Post by shineydave » Wed Feb 21, 2007 6:58 pm
and a doddle to fit, bolt straight on
Nige_RS4
Post by Nige_RS4 » Wed Feb 21, 2007 8:22 pm
RS6 Calipers & pads on std RS4 discs are also excellent, then upgrade to B7 RS4 discs when you need to.
If you're handy with a spanner, then get them from dsgwagen via ebay (mention RS246 and he will give you a discount!).
If you don't fancy getting your hands dirty, then MRC will sort you out!
HTH
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
MarkB
Re: RE: RS6 front brakes onto RS4 B5
Post by MarkB » Wed Feb 21, 2007 8:25 pm
Nige_RS4 wrote:RS6 Calipers & pads on std RS4 discs are also excellent, then upgrade to B7 RS4 discs when you need to.
HTH
Is that what you've done Nige? I'm thinking the same as a first step... Well, second step, running standard B5 RS4 at the moment
Mark
Nige_RS4
RE: Re: RE: RS6 front brakes onto RS4 B5
Post by Nige_RS4 » Wed Feb 21, 2007 8:34 pm
Yep, Doug will vouch for how effective they are ;-)
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
cpt_splash
Post by cpt_splash » Wed Feb 21, 2007 8:46 pm
I am about to do the very same mod.
APS is Brackley do the whole kit for £1400 + VAT & fitting (2-3 hrs), AmD do their Monster kit for around £1700, VAGPARTS do the RS6 kit for £1280 + VAT. I went to my local main Audi stealer and they wanted, get this, £450 per caliper, plus £206 for RS6 pads, plus £360 per front disc!! Madness, nearly £1900 for the same parts as the specialists.
I am having standard rear discs fitted but will upgrade to the RS6 front. Not sure where to buy yet though. I have seen on ebay front B7 RS4 discs for £474 per pair, so this makes it more cost effective. I also saw both RS6 calipers on the German ebay site for £700.
B5 RS4 - RS6 Calipers/B7 RS4 Discs, H&R ARB's, MRC Custom Remap, RS246 Sticker!! SOLD!!
quattrosteph
RS6 brakes
Post by quattrosteph » Wed Feb 21, 2007 9:03 pm
MRC did fit some RS6plus set on mine a while ago and the difference is massive.
Give them a call they may offer you a good deal 8)
Porsche 996 Turbo S Atlas Grey.
RS4 B7 Avant Sprint Blue. Sold.
RS4 B5 Avus Silver with MRC magic . Sold (Best car ever )
S4 B6 Avant Nogaro blue. Sold
A6 Avant Silver . 2.5 TDI .Sold
Nige_RS4
RE: RS6 brakes
Post by Nige_RS4 » Wed Feb 21, 2007 9:05 pm
RS6 calipers are around £240+VAT at the moment if you shop around!!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Golich
RE: RS6 brakes
Post by Golich » Wed Feb 21, 2007 9:44 pm
Don't forget the RS6 brake pipes if you don't fancy bending the stock RS4 flexi pipes.
Jarv
Post by Jarv » Wed Feb 21, 2007 9:49 pm
I went for the full Brembo RS6 8 pots with RS4 B7 floating vented cross drilled discs. Absolutely fantastic.
I too was considering a halfway house measure of just bolting the new calipers onto my existing B5 discs. It would have worked, but as the discs are smaller there would have been a small amount of the pad running off the discs, which would have meant that, when I upgraded the discs I would have needed a new set of pads as well, so I considered it false economy.
Mike
Q7
Doug_S2
Trader (Expired)
Post by Doug_S2 » Wed Feb 21, 2007 11:14 pm
we do the full kit for £1250 inc!
http://www.MRCtuning.com
cpt_splash
Post by cpt_splash » Wed Feb 21, 2007 11:15 pm
Just been reading some posts about fitting VW Phaeton ducts at the front. How easy is this to do and does it make that much of a difference wit the RS6 set-up?
cpt_splash
Post by cpt_splash » Wed Feb 21, 2007 11:16 pm
Does that price include fitting Doug?
Users browsing this forum: No registered users and 115 guests
