B5 S4 Clutch advice
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
fraser29
B5 S4 Clutch advice
Post by fraser29 » Fri Jan 19, 2007 4:19 pm
Its a long story so I will not bore you with the details but a minor shunt has now meant due to others incompetence that a new engine is being fitted to my beloved S4 even though the old one had only covered 52K! WHilst this work is being undertaken (I hasten to add this works is being undertaken by alternative specialists rather than the body repairers) I was thinking that it would be worth having the clutch changed. Have any of you got any advice on whether I should replace with a stock item from Audi or uprate from alternaive supplier. Many Thanks
JonnyX
RE: B5 S4 Clutch advice
Post by JonnyX » Fri Jan 19, 2007 4:26 pm
Depends on how much torque you are running (planning on running) and whether you are going to
change the flywheel or not. Most upgrade to the RS4 clutch which is essentially the same friction disk
but with a higher clamping force. If you don't plan to go K04's then you probably don't need to upgrade
the clutch at all as the stock item seem to hold up fine even on remapped cars.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
MCB
Post by MCB » Fri Jan 19, 2007 4:49 pm
Spot on Jonny
S4B5 Avant
fraser29
Post by fraser29 » Fri Jan 19, 2007 5:34 pm
thanks for information. Currently just had revo remap so nothing major and think that I will upgrade to B5 RS4 Avant rather than mod mine even more.
ZeroK66
Post by ZeroK66 » Fri Jan 19, 2007 6:59 pm
RS4 clutch does not really costany more and drives as well. Well worth doing this, be good for 400+HP and a daily driver :) My clutch pedal is actually MUCH lighter since the upgrade, far more pleasant in traffic. Could just be a coincidence though.
mikeyquattro
Post by mikeyquattro » Fri Jan 19, 2007 8:10 pm
depends on how long you are keeping it!
My clutch went at 95k. Standard car though. If you want to pay the extra £200ish then you might as well get it done. But not essential
Tomorrow is another day
Dr-Al
Post by Dr-Al » Mon Jan 22, 2007 10:48 am
Is a clutch change an engine out job or can it be done with engine in place?
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
MarkB
Post by MarkB » Mon Jan 22, 2007 11:14 am
Either engine out or gearbox out... as you would expect I would say
Mark
QuantumJohn
Post by QuantumJohn » Mon Jan 22, 2007 11:43 am
The book says 10.4 hours to remove downpipes (or you can get away with removing one) lower rear of front subframe, remove gearbox change clutch and refit.
After the weekend I would say that time is just about right as well!
John
Doug_S2
Trader (Expired)
Post by Doug_S2 » Mon Jan 22, 2007 11:54 am
usually 7 to 8 hours if everything comes off ok to do a clutch, removing the box.
http://www.MRCtuning.com
GrimReaper
Post by GrimReaper » Mon Jan 22, 2007 6:31 pm
been looking into clutches recently and had a mooch around the recent Autosport show but manufacturers couldn't help me. Basically i want to allow for furue upgrade so that i dont have to pay twice for things. At first i was just going to change the stock clutch for the RS4 one. Now whilst its out i have been tempted to get rid of the dual mass for a lightened flywheel. I take it the RS4 clutch isn't centre sprung since that would run dual mass as well. Got sent a link for a flywheel from the states http://www.034motorsport.com/product_in ... cts_id=602 dont really know much about this sort of thing. Is it worth changing the flywheel when it come the clutch time and obviously suitable clutch to use with it or should i just stick in the RS4 and keep the dual mass wanna doa couple of RWYB days this yearplus i have Nurburg trip in the summer. Eventually want to go down the k04 route just would be cheaper now than having to take it all off again in the near future.
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
MarkB
Post by MarkB » Mon Jan 22, 2007 6:55 pm
Tanoga do a lightweight flywheel. DavidT is running one...
Mark
JonnyX
Post by JonnyX » Mon Jan 22, 2007 8:23 pm
I think it depends on your driving style. I would go the RS4 clutch route and flywheel for day to day
temperament. If you get a lightened flywheel and uprated clutch (i.e paddle) they tend to chatter at low revs,
and the engagement point is generally a lot more 'positive'. Probably not nice if you sit in traffic a lot.
On AW, the Clutchmasters stage 3 or 4 clutch with the stock flywheel seems to be a good compromise
between pedal feel and drivability.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
DavidT
Post by DavidT » Mon Jan 22, 2007 8:26 pm
It's the lightweight flywheel that causes the gear chatter. Dual mass flywheels damp this.
okkim
Post by okkim » Mon Jan 22, 2007 8:47 pm
I'm installing a Clutch Masters stage 4 clutch and Fidanza flywheel. The flywheel makes a little chatter below 2000 rpm if torqueing, but nothing serious. That clutch looks very strong :D
The clutch pressure plate is originally from Sachs, but it is modified.
Users browsing this forum: No registered users and 156 guests
