Strange feeling on turning
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Kaapse_Laaitie
Post by Kaapse_Laaitie » Thu Jan 11, 2007 5:00 pm
Guys I need help to identify a problem with my steering (I think???) When I turn the steering and pull away, I get a feeling that the wheels or whatever drives the wheels is slipping. At the same time there is a grinding/slipping feeling on steering. Could it be bearings, cv's or anything else major?
I also get the feeling this will be costly to fix. I already have tracking rods to replace. I get the feeling someone will be able to help me.
I doing just like my wife said. Get in touch will your feelings. :bigblink:
fletchie55
RE: Strange feeling on turning
Post by fletchie55 » Thu Jan 11, 2007 5:09 pm
the diff will make a noise if you turn the wheel a lot and pull off, does it on my car and dont think its a problem or at least I hope it isnt
has this just started happening or has it always done this?
have you changed the wheels/tyres recently? I think larger wheels might make this more apparant as the wheels move a greater distance for the same turn on the axle.
Si4
Post by Si4 » Thu Jan 11, 2007 7:41 pm
i think it's just the way quattro is on tight turns at slow speeds, however mine got less apparent when i had my laser wheel alignment done..
worth a try - alignment makes a big difference to the feel of the car if it hasn't been done for a long time or you've had suspension work done.
'99 S4, RS4 shocks, Ali mirrors, MTM reps, 710n's, W8 Under tray and the much loved after run pump mod.
fletchie55
Post by fletchie55 » Thu Jan 11, 2007 8:18 pm
also tyre pressures make a difference to the noise
Mcdubber1
Post by Mcdubber1 » Thu Jan 11, 2007 9:10 pm
mine also does this.... just had new suspension fitted so laser alignment is on the to do list.... hopefully it makes it less noticeable.
S4 Avant
Mk1 Golf Gti
Mcdubber1
Post by Mcdubber1 » Thu Jan 11, 2007 9:11 pm
S4 Avant
Mk1 Golf Gti
Kaapse_Laaitie
Post by Kaapse_Laaitie » Fri Jan 12, 2007 3:21 pm
I had no idea the problem was that common. Well is it a problem or is that just the way the car is / character???
It feels more like the wheels are about to come off on a fast pull-away.
My tyre pressure is fine (35 @ back & 37 @ front). I really need to feel the different between my car and someone else to decide whether mine is as bad as I thinks. Tracking needs to be done, but not until the tracking rods are sorted out.
I have bigger wheels on: "18/225 RS4 replica's. Could that be a factor??
GrahamS4
Post by GrahamS4 » Fri Jan 12, 2007 3:45 pm
Never felt anything like the problem described.
ZeroK66
Post by ZeroK66 » Fri Jan 12, 2007 5:08 pm
If I have the car on tight lock and I accellerate you get a vibration grinding through the quattro system. This is perfectly normal - assuming you feel it through the body of the car not the steering? My 2.8quattro did the same.
Users browsing this forum: No registered users and 96 guests
