Brakes?
S4TAN - the only reason I ask is because i have been thinking about the brake upgrade for a while. I think when Cliveh did his brake upgrade, he too originally had 5mm spacers on his B6 18's, and then he had to get 10mm. Clive then hcnaged his wheels for a set with ET35.
I love the look of the RS6 calipers and B7 disks, but I'm not sure if the wheels would like "right" sitting out another 5mm. Please post pics when done......
Good luck
Good luck
I think i have posted on this thread once before but the B5 RS4 set up is relitivly cheep and is a good and noticeable upgrade for the S4. The difference is vast and i dont see the point in spending Thousands on brakes unless you do loads of track days or are running more than 400bhp. IMHO ofcourse.......Oh no im gonna get burned for that arnt i
Wide Body S4
Deus ex machina
B5 RS4 callipers, Discs and pads. To give you an idea i payed £150 for the lot. Calipers in good condition, Discs have 1 set of pads worth left on them and the pads were 40% worn. Just bought new mintex pads from ebay £31 delivered so not too bad. New discs £300 + which is a bit of a sting. They are a straight swap with the S4 brakes. Took me 45 mins to do both sides. good luck
Wide Body S4
I had Mintex put on a month ago. They are much better than what came off (Lucas?). But then about 25% of the friction material had disintegrated on 4 of the 8 pads! So I can't say that this is a fair comparison between Mintex and OEM.
edit: PS Mintex aren't cheap. Mine were £90 fitted inc VAT
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
