Upgrading BOSE headunit to Becker Head Unit
I want to keep all the BOSE system but am considering upgrading the head unit to a quality Becker, OEM look, bluetooth + hands free, ipod integration etc..
http://www.caraudiodirect.co.uk/product ... ts_id=5092
I know the BOSE has line level speaker outputs & obviously the Becker will have pre-outs.
Is there anyway to convert these to suit the BOSE amp?
Also, doubt this very very much, but anyway to hook this up to the DIS?
R
R
RE: Upgrading BOSE headunit to Becker Head Unit
did you buy that lead? if so any good,
ive got a pioneer unit from my old car, its got no built in amps only 3 preouts!
i'd like to use this as the volumes playing up on the audi one
99 S4 minging blue avant
What's the issue? Does it go crazy from time to time when you touch the volume control? If so, this is a common problem and can be fixed by a UK-based company (nr Swindon) for around £70 - probably a bit cheaper than replacing the entire system (but the becker unit does look good!)nope im still learning, the cars got bose speakers and the sub thing in the boot, tho im thinking of ditching the lot and fitting a complete new system, as the headunit has volume issues?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
You wont need to ditch any of the rest of the system (unless you want to) the lead above will allow you to use the pioneer head unit with the existing Bose speakers/amp/sub in your car, you will need to buy a fitting adaptor http://www.caraudiodirect.co.uk/product ... 3354f54d6b to allow the pioneer unit to fit.
If you already have the head unit then you might as well put it in, cheaper than getting the unit repaired and will sound better as well.
back to that lead, the new pioneer has 2 pre outs one for fronts the other for ( subwoofer or non-fading output ) dont want to spend the £40 to find its bo good? any ideas?
starting to look easyier to ditch the bose set up, headunits mosfet 50W x 4 , enough for the door speakers and drop a 10" sub in the sparewheel and amp in the side compartment?
a bit more info here, http://www.nexxia.co.uk/Car_Stereo_fitt ... udi/A4.htm
then click PC9-408 instalation tip
head unit sticks out the dash just under an inch! bugger, the plastic end caps fit poorly, not great all round really, at the mo.
aerial plugs straight in, needed no adapter?
now im not sure if the adapters added some hiss or not, is deff clearer and louder, but my ears aint good, hope to compare it to a standard bose, 2 saturdays time
