Interesting.......veeeerrrry interesting
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
h8cak
Post by h8cak » Fri Nov 10, 2006 11:12 pm
Have just removed mine. :?:
Wide Body S4
h8cak
Post by h8cak » Fri Nov 10, 2006 11:13 pm
Took 3 mins in total. Just poped the plastic flow thingy out and the mesh fell out:)
Wide Body S4
Dr-Al
Post by Dr-Al » Fri Nov 10, 2006 11:34 pm
h8cak wrote:Took 3 mins in total. Just poped the plastic flow thingy out and the mesh fell out:)
Ah - so the mod is reversible if you do it this way.
Then there's no reason not to try it if you have the time...
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
h8cak
Post by h8cak » Sat Nov 11, 2006 1:13 am
Yes totally reversable. And a lot quicker this way IMHO :) ( No offence intended S4TAN )
Wide Body S4
CliveH
Post by CliveH » Sat Nov 11, 2006 10:18 am
As I understood Stephen Hawking, time may be reversible under certain circumstances...Doc?
Clive
philipwalker
Post by philipwalker » Sat Nov 11, 2006 10:45 am
CliveH wrote:As I understood Stephen Hawking, time may be reversible under certain circumstances...Doc?
Something to do with the faster you go the younger you get.
I try that every time I drive, still the grey hairs are appearing??
A comment from a local copper "attempting some time travel were we sir?"
jimbogrey
Post by jimbogrey » Sat Nov 11, 2006 10:55 am
Had a spare MAF sitting around so tried it and bingo plastic grill pops out and mesh falls out less than 30 secs, but will it makle any difference when i get VAG-Com working i will run some comparisons.
Jimbo#
Dr-Al
Post by Dr-Al » Sat Nov 11, 2006 12:26 pm
:lol:
I use the same line with my wife every time she says "Why do you have to drive so fast - we're not in a hurry"
She doesn't believe me :cry:
Philws4
Post by Philws4 » Sat Nov 11, 2006 5:39 pm
Right, i have been out to "tinker" this arvo and wanted to ask how you get the plastic flow mesh out without damaging/splitting the surrounding pipe?I havent got a security torx bit so would prefer to do it from the other end(air filter end) leaving the MAF in place. It does move very slightly but seems to be held in place quite securely with plastic tabs.
As usual any help greatly received .
Phil
B5 S4
h8cak
Post by h8cak » Sat Nov 11, 2006 9:23 pm
A couple of small screw drivers is what i used
Wide Body S4
jimbogrey
Post by jimbogrey » Sat Nov 11, 2006 9:57 pm
h8cak wrote:A couple of small screw drivers is what i used
Me too not too much pressure and it just eases out
jimbo
Philws4
Post by Philws4 » Sun Nov 12, 2006 11:10 am
Ok, ta for that i will go and give it a go!!
B5 S4
S4TAN
Post by S4TAN » Sun Nov 12, 2006 1:07 pm
With your charm and my science, maybe we could do a Brainiac-like spot on the Audi channel
Charm eh? Well I'm often called something that begins with"c" but i'm sure it ain't "charming"...! :biggrin3:
Deus ex machina
CliveH
Post by CliveH » Sun Nov 12, 2006 1:28 pm
Cavalier...?
Clive
S4TAN
Post by S4TAN » Sun Nov 12, 2006 1:35 pm
Nah.......your "clock" runs slower the faster you travel relative to slower moving bodies, therefore the faster you travel the slower you age relative to others travelling slower than you, especially as you approach 'c' - the speed of light - you can never get younger unfortunately, and you still age at the same rate "internally" i.e. 1 second per second, it's just that at high velocities 1 second to you equates to many seconds/minutes/hours etc for others travelling at slower velocities (the ratio is dependent upon the delta between your relative velocities) .....Relativity and quantum physics are pet subjects of mine......
Suffice it to say: even Mihnea's car doesn't have the capability to approach 'c' so i'm afraid none of us will age slower relative to non-S4 drivers unfortunately - and in my case my life may even be foreshortened what with me having crap brakes!
:smile_smoking:
Deus ex machina
