DTS
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
reserves
Post by reserves » Wed Nov 01, 2006 6:58 pm
They haven't even responded to my email!
Russ,greys4
Post by Russ,greys4 » Wed Nov 01, 2006 7:16 pm
how hard is it 2 fit DTS?
The lowriders gone! But still loved. Long live the 911-C2!!!
S4TAN
Post by S4TAN » Wed Nov 01, 2006 7:17 pm
Piece of p!ss
Deus ex machina
philipwalker
Post by philipwalker » Wed Nov 01, 2006 7:59 pm
Just make sure you clean the threads on the g/box mount
http://www.pwmotorsport.com
PW Motorsport
01437 563929
S4TAN
Post by S4TAN » Wed Nov 01, 2006 8:10 pm
...and re-cut them if necessary before mounting the bush to the g/box
Deus ex machina
h8cak
Post by h8cak » Wed Nov 01, 2006 10:10 pm
Im still waiting on a email from them?
Wide Body S4
Russ,greys4
Post by Russ,greys4 » Wed Nov 01, 2006 11:09 pm
any picks? why am i looking, havent got the damn thing yet! is it a ramp job? or a drive jobby? :boots:
whisky180
autospeed
Post by whisky180 » Wed Nov 01, 2006 11:21 pm
h8cak wrote:Im still waiting on a email from them?
i found the best way was to phone
noggy blue s4, mildly modded
S4TAN
RE: autospeed
Post by S4TAN » Thu Nov 02, 2006 6:17 pm
Did mine on the driveway - jacked the front up and put ramps under the wheels. Main thing to be aware of is supporting the transmission housing when you take off the 2 factory-fitted transmission suspension plates (triangular shaped metal plates on either side of the car) as the trans housing will drop when these come off. I used a jack to hold it in place. You'll see when you get the thing; it's all clearly described in the instructions. But as stated above make sure the threads are good on the 2 holes in the g/box before attaching the rubber bush - try putting the bolt in on it's own first and see how far it will screw in - if not very far then spray WD-40 into the holes and gently re-cut the threads till the bolt goes in fully - when you've done that then take the bolts out and attach the rubber bush....etc.
Deus ex machina
GrimReaper
Post by GrimReaper » Fri Nov 03, 2006 2:04 am
Sorry for being abit of a div, but can someone briefly explain the advantages of the DTS? is it for dampening? I have noticed the DTS topic come up a few times so i assume its a bit of a must have mod to do. Going to Nurburg next summer so wanna make sure i have the car running tip top by then.
Steve
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
saf
Post by saf » Fri Nov 03, 2006 4:33 am
DTS stands for drive train stabilizer.
You must surely notice the kangarooing effect when changing gears. The gearbox moves back and fourth and makes a very uncomfortable soind. The DTS is basically a special metal shaped bar that bolts the drivetrain to the car to minimise the the kangarooing effect of the drivetrain. This provides a more solid gear change without the jerkiness as well as putting less pressure on where the drivetrain is secured.
From the site
The AWE Tuning Drive Train Stabilizer (DTS) eliminates the excessive engine and transmision torsional movement found in these vehicles. The results are phenomenal throttle response, crisper and more precise shifts, and more power to the ground.
S4TAN
Post by S4TAN » Fri Nov 03, 2006 11:11 am
S4woody would disagree with that........... (see a previous DTS thread):lol:
Deus ex machina
MarkB
Post by MarkB » Fri Nov 03, 2006 11:19 am
So am I right in thinking there is a bar there as standard, justnot as beefy as the DTS, or the bar that is there doesn't connect to the gearbox?
Mark
S4TAN
Post by S4TAN » Fri Nov 03, 2006 11:22 am
The small black bar that's there doesn't clamp up to the gear box - it's like a cross-brace, but doesn't stop any g/box movement....
Deus ex machina
MarkB
Post by MarkB » Fri Nov 03, 2006 11:27 am
S4TAN wrote:The small black bar that's there doesn't clamp up to the gear box - it's like a cross-brace, but doesn't stop any g/box movement....
Ah OK. I hate getting under cars so thought I'd ask ;)
Mark
Users browsing this forum: Majestic-12 [Bot] and 74 guests
