Timing Chain noise again !!
tuscy
Post by tuscy » Fri Oct 27, 2006 7:42 am
I'm having the same timing chain noises on my 04 S4 Avant.
I was wondering how difficult it was for you to get the dealer to accept there was a problem. Did they acknowledge it as a known issue?
I only really notice mine when firing up in the morning, and the cold weather seems to lessen the noise, presumably because the cold oil is more viscous and doesn't leak out of the tensioner so quickly.
This may hinder my attempts to get a warranty fix before it expires in March - especially if the dealer denies any knowledge of the problem.
Surely this is a problem with all Audi V8's of a certain vintage???
Scotty
Post by Scotty » Fri Oct 27, 2006 7:32 pm
I had no issues with my dealer when I showed him the bulletin. Others have had a nightmare.
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
tuscy
Post by tuscy » Thu Nov 02, 2006 2:05 pm
Can anyone point me to a copy of the Timing Chain TSB?
Or give me the reference number?
Scotty
Post by Scotty » Fri Nov 03, 2006 12:35 am
That one and more : HERE
B8 A4 Avant quattro
philipwalker
Post by philipwalker » Fri Nov 03, 2006 9:09 am
Scotty wrote:That one and more : HERE
"Tip tip" Thanks.
tuscy
Post by tuscy » Tue Nov 07, 2006 1:57 pm
Errr ... can't see anything here about timing chain tensioners. Only stuff about front rubber belt tensioner.
nidfix
Post by nidfix » Wed Nov 15, 2006 9:10 pm
Can someone confirm or invalidate the information about this TSB ?
I went through many TSBs related or not to the S4 and the only thing I can find is TSB150401 superseded by TSB150603 which on contrary declare that for many motors (but S4) it is normal to have some rattle at start.
Thanks in advance.
Scotty
Post by Scotty » Thu Nov 16, 2006 11:42 pm
If you get this sound then it gets fixed with the tsb.
HERE
B8 A4 Avant quattro
nidfix
Post by nidfix » Fri Nov 17, 2006 12:19 am
Scotty wrote:If you get this sound then it gets fixed with the tsb.
HERE
Many thanks !!!
At least it is clear which noise is supposed to be addressed with this tsb
In my case, I have the rattle you can hear just after you started and not the whine you experienced.
Scotty
Post by Scotty » Sat Nov 18, 2006 8:57 pm
Every one gets a sort of rattle which is the chains before they tighten. Not sure if this is what you have though.
B8 A4 Avant quattro
nidfix
Post by nidfix » Sun Nov 19, 2006 3:46 pm
Scotty wrote:Every one gets a sort of rattle which is the chains before they tighten. Not sure if this is what you have though.
The point was for me to get confirmation from Audi (which I never got) on whether it was normal or not. I never had that in the past with the BM and before my extended warranty expired, I wanted to be sure.
Again many thanks for the little document and I hope yours will get quickly fixed.
B6S4John
Post by B6S4John » Sun Nov 19, 2006 5:43 pm
HERE
This is nothing like the sound I got.
Mine was a rattle and then clunk.
Last one dead's a sissy.
nidfix
Post by nidfix » Sun Nov 19, 2006 10:56 pm
HERE
From what I learned, they produced a change about the control of valves in admission and the exhausts. Without that update, in addition to the rattle, you can have some beat noise.
That the change I had on mine and only left the rattle. In addition the throttle response is definitely smother now.
julianb
Post by julianb » Mon Apr 14, 2008 12:07 pm
I have the same issue. If anyone who has had this fixed and has a reference number (and ideally is prepared to supply their dealer name and reg number) I'd really appreciate it as I'm having a nightmare getting Audi to recognise this as a common problem -- demanding some evidence of it occuring elsewhere. Thanks
else
Post by else » Tue Apr 15, 2008 9:49 am
Hi All, I have the same issue. Rattle clonk clonk on start up, every time from cold or if it has been left for half an hour or more from hot.
It is an 05 with 25k on the clock.
The dealer topped up the oil and said it was better at the first attempt ot cure it, i personally can't detect any difference. They are also dealing with some other issues, no problems with accepting liability so far, can't fault them.
Its going in at the end of the month for a new rear diff, slight clonking on hard acceleration in 1st and 2nd gears, factory advised diff change. I'll ask them to look further at the timing chain rattle clonk then. I would also like any correspondence that shows Audi recognise this as a fault in case it gets nasty.
Nidfix, do you have a TSB or other reference regarding that update, it might help mine also.
Andy
