rs4 clutch in an s4??
mikecmr
Post by mikecmr » Wed Oct 11, 2006 3:01 pm
what do i need and how much are we usually talking to do this?
local sports garage said they will fit it (he use to be head mechanic on alfa touring car team so knows his stuff) found the clutch on vag parts but do i need anything else?
If its too big a job do you recommend taking to mrc?
DavidT
RE: rs4 clutch in an s4??
Post by DavidT » Wed Oct 11, 2006 3:03 pm
From memory, gearbox is 4 hours, I don't think you need a specialist to do it, the RS4 one is a direct fit.
Out of interest, why are you upgrading please ?
mikecmr
Post by mikecmr » Wed Oct 11, 2006 3:08 pm
Reason for upgrade is its running rs4 turbos, so im thinking it will give way eventually and better to get it done now while i know the box etc is in good order more pre-ventative than anything else
mikecmr
Post by mikecmr » Wed Oct 11, 2006 3:09 pm
just been on vag parts and this is what they are selling
RS4 clutch
Direct replacement RS4 clutch for the 2.7T S4. Parts supplied: pressure plate and center plate
Order number: 078198031
Our price: 227.01
is this all i need? and of course a grease monkey to fit it haha
DavidT
Post by DavidT » Wed Oct 11, 2006 3:20 pm
I did the same thing at 76k miles and for the same reason but my engine was out for turbos anyway, so it was a no brainer. The S4 clutch was in very good condition and would have been fine for plenty more miles.
I'd wait for it to slip before upgrading to be honest :?:
ZeroK66
Post by ZeroK66 » Wed Oct 11, 2006 6:36 pm
Agreed with David - this seems to be the common view. The S4 clutch is pretty darn good. When it starts to slip then look at upgrading.
S2tuner
Trader (Expired)
Post by S2tuner » Wed Oct 11, 2006 7:15 pm
Haven't we done the clutch on that car when it was still Andy's??? Oh wait, maybe not....
mikecmr
Post by mikecmr » Wed Oct 11, 2006 8:04 pm
no dude andy never had it done at the time :(
grizz
Post by grizz » Wed Oct 11, 2006 10:07 pm
Try the dealers for a clutch , the are vgood on there prices . g
Unit 20
0151 3366888
mikecmr
Post by mikecmr » Thu Oct 12, 2006 6:44 pm
cheers dude im sure its starting to slip tbh or i might just be getting paronid well its coming out anyway haha
Dippy
Post by Dippy » Fri Oct 13, 2006 11:07 pm
I have done 60K and am still on the original clutch. I assume they are self-adjusting so my clutch still works as well as it was when new???
2001 Silver S4 Avant
mikecmr
Post by mikecmr » Wed Oct 18, 2006 10:00 am
165 quid from gsf carparts or 225 from vagparts seem quite good was thinking that they would be a lot more
saf
Post by saf » Fri Oct 20, 2006 6:39 pm
make sure the gsf part is an original part and not a copy part.
Otherwise if its a copy part you may as well stick with the S4 clutch.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Oct 29, 2006 4:10 pm
From memory a genuine Audi RS4 clutch kit with clutch disc, pressure plate, bolts and release Bearing is around £290.
One customer had a clutch problem and got his clutch replaced twice by audi - in the end it was the flywheel that warped but audi still honoured the parts warranty.
Clutch replacement is 10 hour book time but usually takes 7-8 hours.
They are self adjusting - this adjustment needs to be checked before fitting.
I am surprised the clutch is slipping unless it has had a lot of abuse, or 4k+ launches - stock s4 are usually ok for 400bhp cars.
http://www.MRCtuning.com
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Nov 07, 2006 9:38 pm
Run an RS4 clutch in my car for 2 years No problem.. but as MRC say over 400bhp with 3K launches it slips.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
