a bulk head full of water
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
craigs4
Post by craigs4 » Mon Sep 18, 2006 8:06 pm
hi all, ive got a couple more for you .
first , the void under the battery and ecu is full of water , well a couple of inches anyway, so where do i look for the drain hole before i start stripping everything out?
secondly , when i unlock the car (with the fob) the hazzards flash twice but when i lock it nothing flashes at all and the led,s in the door pins dont ever flash . and the button in the drivers side centre door pillar doesnt apear to do any thing either but i dont know if this is related.i thought the hazzards were supposed to flash 3 times when you lock it.
ANY IDEAS ?
springfield
RE: a bulk head full of water
Post by springfield » Mon Sep 18, 2006 8:28 pm
Your drain holes in the bulkhead 2 off will be clogged with all matter of <beep> take the battery out and you will see them/feel them poke them out(oo..... err) with a screwdriver or similar.
Sorry cannot help with your locking questions.
Jim.
Imola Avant,Carbon,Bose,MRC Re Map,Hyperboost DV.s.
BMW E30 318iS.
craigs4
Post by craigs4 » Mon Sep 18, 2006 8:31 pm
thanks springfield
shineydave
Post by shineydave » Mon Sep 18, 2006 11:07 pm
Hazards should flash on locking. could be a dodgy bonnet switch that's not allowing the alarm to arm fully. all the others can be checked by seeing if the relevent lights have gone out.
iaincherry
Post by iaincherry » Tue Sep 19, 2006 9:08 am
Let me know if you manage to clear the drain holes - I washed the car at the weekend and lifted the bonnet to find a pool of water that an Olympic Swimming Team would have been pleased with - it was so deep that everything was submerged. What did you have to take out - how many drain holes - and where are they??
Cheers, Iain
drop the hammer...
QuantumJohn
Post by QuantumJohn » Tue Sep 19, 2006 10:18 am
Iain,
The easiest drain hole to get to is the one under the battery. Take the battery out and you will see the hole throuhg a cut out in the battery tray. If you really want to clean out all the leaves and other material that's collected there take teh abttery tray out as well - it's only 1 bolt and 2 nuts.
John
iaincherry
Post by iaincherry » Tue Sep 19, 2006 10:34 am
John, that's superb, thanks. My power steering was whining for weeks - I wet-vacced the bulkhead area, let it dry out - and the noise has disappeared. Co-incidence, or a consequence do you think?
Cheers, Iain
drop the hammer...
QuantumJohn
Post by QuantumJohn » Tue Sep 19, 2006 10:45 am
Co-incendence probably. The power steering whining normally comes from the pump which is towards the front on the passenger side of the engine.
However the steering rack is right under the bulkhead area so perhaps.
John
KayGee
Post by KayGee » Tue Sep 19, 2006 11:22 am
maybe it washed it when all that soapy water fell out...
there are quite a few options with regard to alarm setting etc... in Vagcom. Worth checking there before getting to excited and ripping everything out.
DavidT
Post by DavidT » Tue Sep 19, 2006 11:31 am
My alarm did not flash the lights on unlock when the battery was low (knackered) but it did when I locked it. New battery is fine :?
Users browsing this forum: No registered users and 214 guests
