S4 key recoding
fletchie55
S4 key recoding
has anyone here recoded an S4 key? I have managed to get hold of a new key as the last one got snapped off, but I cant seem to find how to re-code the transponder.
- shineydave
RE: S4 key recoding
i think the transponder has to be done at a dealer unless you have acces to the security pin. has your new key been cut yet?
Dave
RE: S4 key recoding
You can do it yourself if you have two transponders - the working one goes in the ignition while you re-code the other one. I have this info on file somewhere if you need it.
S4B5 Avant
RE: S4 key recoding
Unless you have the specific code required you won't be able to do it yourself. Job for the dealer these days. You can get the buttons working yourself with some clever key presses.
Mark
RE: S4 key recoding
There is a posting on the forum somewhere letting you know how to re-programme the fobs. Try the search facility....I'm sure I've got a copy of it somewhere at work....hopefully find it tomorrow and will post it.
Paul
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin
If you dont "do it now" you never will.
Huge Grin
- shineydave
RE: S4 key recoding
the remote part of it is as simple as putting the key in the door, unlocking it and then pressing the open or close button for 5 secs. the tricky bit is the transponder for the immobillisor
Dave
Re: RE: S4 key recoding
Thats the bit the dealer has to doshineydave wrote:the remote part of it is as simple as putting the key in the door, unlocking it and then pressing the open or close button for 5 secs. the tricky bit is the transponder for the immobillisor
Mark
S4 key recoding
Can't remeber where I found this, won't do any harm to try:
- Attachments
- clip_image001.jpg (37.73 KiB) Viewed 1299 times
- clip_image002.jpg (16.15 KiB) Viewed 1299 times
S4B5 Avant
fletchie55
RE: S4 key recoding
thanks guys!
basically I still have the original key blade which has snapped off the transponder unit. I have a new transponder unit with someone elses key blade on it still. I was hoping to be able to use that transponder (as it looks much newer) with my old key blade, but it doesnt sound like this will be too easy!
fletchie55
RE: S4 key recoding
thanks guys!
RE: S4 key recoding
An Audi Stealer will charge you approx £50 (No less) to sort this out for you or alternatively you could try:
1. Have a new blank key cut and have them fit it to your new - not working transponder.
2. Jury rig your old key together - tape or whatever you can use.
Then try the instructions in my post.
S4B5 Avant
RE: S4 key recoding
By the way I would fit a new battery in your new transponder before you do this as if the battery goes there is a chance you will have to do all this again.
S4B5 Avant
The transponder isnt battery driven and cant be recoded with the ignition trick - this applies only to the infra red/central locking component of the key.MCB wrote:By the way I would fit a new battery in your new transponder before you do this as if the battery goes there is a chance you will have to do all this again.
Youll probably need to pay the stealers unless http://www.rs246.com/index.php?name=PNp ... ht=#130671
- shineydave
RE: Re: RE: S4 key recoding
get your new key cut to match the car then knock the pin out of the base of the key blade and swap it into your old transponder, bingo, job done. you'll be using your old remote and transponder, will that do it?
Dave
