S4 key recoding
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
fletchie55
S4 key recoding
Post by fletchie55 » Thu Sep 14, 2006 8:04 pm
has anyone here recoded an S4 key? I have managed to get hold of a new key as the last one got snapped off, but I cant seem to find how to re-code the transponder.
shineydave
RE: S4 key recoding
Post by shineydave » Thu Sep 14, 2006 8:57 pm
i think the transponder has to be done at a dealer unless you have acces to the security pin. has your new key been cut yet?
Dave
MCB
RE: S4 key recoding
Post by MCB » Thu Sep 14, 2006 9:01 pm
You can do it yourself if you have two transponders - the working one goes in the ignition while you re-code the other one. I have this info on file somewhere if you need it.
S4B5 Avant
MarkB
RE: S4 key recoding
Post by MarkB » Thu Sep 14, 2006 9:08 pm
Unless you have the specific code required you won't be able to do it yourself. Job for the dealer these days. You can get the buttons working yourself with some clever key presses.
Mark
derdle
RE: S4 key recoding
Post by derdle » Thu Sep 14, 2006 9:16 pm
There is a posting on the forum somewhere letting you know how to re-programme the fobs. Try the search facility....I'm sure I've got a copy of it somewhere at work....hopefully find it tomorrow and will post it.
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
shineydave
RE: S4 key recoding
Post by shineydave » Thu Sep 14, 2006 9:24 pm
the remote part of it is as simple as putting the key in the door, unlocking it and then pressing the open or close button for 5 secs. the tricky bit is the transponder for the immobillisor
Dave
MarkB
Re: RE: S4 key recoding
Post by MarkB » Thu Sep 14, 2006 10:11 pm
shineydave wrote:the remote part of it is as simple as putting the key in the door, unlocking it and then pressing the open or close button for 5 secs. the tricky bit is the transponder for the immobillisor
Thats the bit the dealer has to do
Mark
MCB
S4 key recoding
Post by MCB » Thu Sep 14, 2006 10:50 pm
Can't remeber where I found this, won't do any harm to try:
S4B5 Avant
fletchie55
RE: S4 key recoding
Post by fletchie55 » Fri Sep 15, 2006 12:56 am
thanks guys!
basically I still have the original key blade which has snapped off the transponder unit. I have a new transponder unit with someone elses key blade on it still. I was hoping to be able to use that transponder (as it looks much newer) with my old key blade, but it doesnt sound like this will be too easy!
fletchie55
RE: S4 key recoding
Post by fletchie55 » Fri Sep 15, 2006 1:12 am
thanks guys!
MCB
RE: S4 key recoding
Post by MCB » Fri Sep 15, 2006 1:29 am
An Audi Stealer will charge you approx £50 (No less) to sort this out for you or alternatively you could try:
1. Have a new blank key cut and have them fit it to your new - not working transponder.
2. Jury rig your old key together - tape or whatever you can use.
Then try the instructions in my post.
S4B5 Avant
MCB
RE: S4 key recoding
Post by MCB » Fri Sep 15, 2006 1:30 am
By the way I would fit a new battery in your new transponder before you do this as if the battery goes there is a chance you will have to do all this again.
S4B5 Avant
maxxximus
Post by maxxximus » Fri Sep 15, 2006 6:51 am
MCB wrote:By the way I would fit a new battery in your new transponder before you do this as if the battery goes there is a chance you will have to do all this again.
The transponder isnt battery driven and cant be recoded with the ignition trick - this applies only to the infra red/central locking component of the key.
Youll probably need to pay the stealers unless http://www.rs246.com/index.php?name=PNp ... ht=#130671
shineydave
RE: Re: RE: S4 key recoding
Post by shineydave » Fri Sep 15, 2006 7:12 am
get your new key cut to match the car then knock the pin out of the base of the key blade and swap it into your old transponder, bingo, job done. you'll be using your old remote and transponder, will that do it?
Dave
MarkB
Post by MarkB » Fri Sep 15, 2006 8:30 am
Was it only the blade that snapped?
Mark
Return to “Audi S and RS Ownership”
