Whoops, what have I broke ?
Olly_K
Post by Olly_K » Mon Aug 21, 2006 1:54 pm
Was thinking about fitting an Ipod into my B5 RS4 today, so I took the cage out of the cubby hole in the boot area. Only to find this :
And on closer inspection, it seems to have snapped off the board :
The "thing" the plug broke off from, has the part number of:
Any ideas what it is and how much to replace ? Not sure if it broke off whilst pulling the cage out or if it was already broken, haven't tried my sat-nav yet, but TV/radio/CD etc all work OK.
Many thanks in advance !
ZeroK66
RE: Whoops, what have I broke ?
Post by ZeroK66 » Mon Aug 21, 2006 1:59 pm
Oh dear... I am sure it is easily enough repaired though... little bit a solder and some patience get it sorted. Be delicate though!
SimonS4MTM
Post by SimonS4MTM » Mon Aug 21, 2006 2:06 pm
Looks like GPS antenna lead, at a guess.
May be possible to repair
Nige_RS4
Post by Nige_RS4 » Mon Aug 21, 2006 2:20 pm
Doesn't look like you need to solder anything, but you may be able to glue the 'tabs' back in place with some araldite. Failing that, you could always gaffer tape the connector to the moddule, as they don't look like electrical connectors that have snapped.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
ZeroK66
Post by ZeroK66 » Mon Aug 21, 2006 2:33 pm
You can see the metal bits on the closeup... it will need soldering.
Olly_K
Post by Olly_K » Mon Aug 21, 2006 3:37 pm
Im really not into repairing it, I'd rather just buy a new one....I'm good with a soldering iron but I just havent got the time.
I also have this installed :
And i'm under the impression this is the AUX TV input, so I'm planning on getting a video Ipod and plugging it right into the composite RCA's to get the audio and the video.
Is my plan correct ?
Nige_RS4
Post by Nige_RS4 » Mon Aug 21, 2006 4:02 pm
Olly, it looks like the connector is broken i.e. the wiring loom - not sure if you can easily buy the plugs?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
shineydave
Post by shineydave » Mon Aug 21, 2006 5:22 pm
isn't that the radio aerial connection, think the other 4 are the TV aerials
shineydave
Post by shineydave » Mon Aug 21, 2006 5:24 pm
yup, plug you're ipod into there and set the head unit to tv then if you press mode you should hear the ipod through the speakers. similar to the way we're connecting our car-pc's in
Olly_K
Post by Olly_K » Mon Aug 21, 2006 5:25 pm
yep i can now confirm I dont have radio, which isnt a bad thing as I dont listen to it anyway !
Jarv
Post by Jarv » Tue Aug 22, 2006 9:21 am
Hi Olly,
It's the switching control box and they're £78 plus vat from VAG Parts. As far as I am aware, it sorts out the signals from the various aerials for radio, TV and sat-nav. It's a bit of a notorious week point as it's tricky getting the cage out of the hole without knocking the connectors. One of the terminals broke on mine when I was investigating a problem with my TV, you can see the photo in the following thread:
http://www.rs246.com/index.php?name=PNp ... ic&t=55072
Jarv
Mike
Q7
Return to “Electrical”
Users browsing this forum: No registered users and 112 guests
