ABS WARNING LIGHT
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
LeeMarshall
ABS WARNING LIGHT
Post by LeeMarshall » Thu Jul 20, 2006 9:35 pm
Hi to all,not been on the site too often lately as been swattin up for exams! But my baby is suffering in this heat (i hope its the heat?) I was driving along when the display started bleeping at me telling me the abs was not functioning correctly and then went off again after a couple of miles! then a few miles later it came up again! it seems an intermittent fault or is this normal? The brakes feel fine and the fluid is at the normal level. has anyone come across this before? could it possibly be the heat?
any info would be great! cheers Lee :(
ChipHazzard
RE: ABS WARNING LIGHT
Post by ChipHazzard » Thu Jul 20, 2006 10:03 pm
Lee
I can think of 4 suggestion's
1) check it out with VAGCOM,
2) it could well be time to change the brake fluid
3) broken ABS rings
4) dirty sensor's
just my thought's for what their worth
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
oliew
Post by oliew » Thu Jul 20, 2006 10:41 pm
or the abs ecu, same as mine went... for about 4 months now its permanently on, abs doesnt work at all.
try Vag Com, if you cant connect to the abs module its defo the ecu. theyre about 250 exchange ive yet to get one! :)
Ol
S4 B5 - MRC
springfield
Post by springfield » Thu Jul 20, 2006 10:46 pm
Mate has the same problem,his is the ABS ecu think you can get them on e-bay.
Imola Avant,Carbon,Bose,MRC Re Map,Hyperboost DV.s.
BMW E30 318iS.
UKS4APR1
Post by UKS4APR1 » Thu Jul 20, 2006 11:54 pm
Very common problem, will affect everyone eventually!
You can fix it yourself (bit tricky and not guaranteed)
Read all about it here..... http://passat-b5.ru/index.php?option=co ... &Itemid=57...
Usual fix is to rplace the ABS module (NOT THE COMPLETE ABS UNIT) which is easy DIY, with a reconditioned unit from someone like BBA-Reman
UKS4APR1
Post by UKS4APR1 » Thu Jul 20, 2006 11:59 pm
UKS4APR1
Post by UKS4APR1 » Fri Jul 21, 2006 12:01 am
Renarl
Re: RE: ABS WARNING LIGHT
Post by Renarl » Fri Jul 21, 2006 6:17 am
I would also place my bets on the ECU. And like UKS4APR1 said, don't buy a new ECU yet! This can be fixed. It is most likely your problem, if one of your sensors is not dead.
The replacement for displacement
LeeMarshall
RE: Re: RE: ABS WARNING LIGHT
Post by LeeMarshall » Fri Jul 21, 2006 10:52 am
Thanks for all the info chaps! its much appreiciated. will try out the abs later to see if it works? will possibly be another post soon about S4 breaking for spares if the ABS has failed! cheers Lee :thumbs:
oliew
Post by oliew » Fri Jul 21, 2006 11:13 am
Lee im from staffs too, do you have vag? i could have a look for you saturday morning or something.
Oli
S4 B5 - MRC
LeeMarshall
Post by LeeMarshall » Fri Jul 21, 2006 11:35 am
Hi Oli,that would be great! i am based in Tamworth, where are you? i dont have a vagcom so would be good to see if anything else comes up? i think i can poss fix the abs module as i have done lots of soldering.Tomorrow would be good for me,where you thinking of? Cheers Lee
oliew
Post by oliew » Fri Jul 21, 2006 11:39 am
Hi mate, if you can fix yours maybe we can do mine too! haha
tamworth is pretty far from me, about 45mins can you get up north a bit towards stoke/newcastle way thats where i am.
Oli
S4 B5 - MRC
LeeMarshall
Post by LeeMarshall » Fri Jul 21, 2006 11:47 am
Hi Oli,i only think i can? we wil see? got the info how to fix from the link from UKS4APR1. have a look! i could meet you at stafford services if thats any good to you? Lee
oliew
Post by oliew » Fri Jul 21, 2006 11:49 am
Same here mate, i have done lots of soldering but my iron hasnt got a very sharp tip on for this kind of detailed work :) stafford services would be fine, pm me your number :)
Ol
S4 B5 - MRC
LeeMarshall
Post by LeeMarshall » Fri Jul 21, 2006 11:52 am
Hi again Oli, ifyou wanna ring me to sort something out my no is:07920132142 i am going out soon but will be back at about 7.30pm cheers Lee
Users browsing this forum: Google Adsense [Bot] and 210 guests
