any info would be great! cheers Lee
ABS WARNING LIGHT
- LeeMarshall
- 1st Gear
ABS WARNING LIGHT
Hi to all,not been on the site too often lately as been swattin up for exams! But my baby is suffering in this heat (i hope its the heat?) I was driving along when the display started bleeping at me telling me the abs was not functioning correctly and then went off again after a couple of miles! then a few miles later it came up again! it seems an intermittent fault or is this normal? The brakes feel fine and the fluid is at the normal level. has anyone come across this before? could it possibly be the heat?
- ChipHazzard
RE: ABS WARNING LIGHT
Lee
I can think of 4 suggestion's
1) check it out with VAGCOM,
2) it could well be time to change the brake fluid
3) broken ABS rings
4) dirty sensor's
just my thought's for what their worth
3) broken ABS rings
4) dirty sensor's
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
or the abs ecu, same as mine went... for about 4 months now its permanently on, abs doesnt work at all.
try Vag Com, if you cant connect to the abs module its defo the ecu. theyre about 250 exchange ive yet to get one!
Ol
Ol
S4 B5 - MRC
- springfield
Mate has the same problem,his is the ABS ecu think you can get them on e-bay.
Imola Avant,Carbon,Bose,MRC Re Map,Hyperboost DV.s.
BMW E30 318iS.
BMW E30 318iS.
Very common problem, will affect everyone eventually!
You can fix it yourself (bit tricky and not guaranteed)
Read all about it here..... http://passat-b5.ru/index.php?option=co ... &Itemid=57...
Usual fix is to rplace the ABS module (NOT THE COMPLETE ABS UNIT) which is easy DIY, with a reconditioned unit from someone like BBA-Reman
Link to BBA-reman.com..
http://bba-reman.com/content.aspx?conte ... ly_failing
Re: RE: ABS WARNING LIGHT
I would also place my bets on the ECU. And like UKS4APR1 said, don't buy a new ECU yet! This can be fixed. It is most likely your problem, if one of your sensors is not dead.
The replacement for displacement
- LeeMarshall
- 1st Gear
RE: Re: RE: ABS WARNING LIGHT
Thanks for all the info chaps! its much appreiciated. will try out the abs later to see if it works? will possibly be another post soon about S4 breaking for spares if the ABS has failed! cheers Lee
Lee im from staffs too, do you have vag? i could have a look for you saturday morning or something.
Oli
Oli
S4 B5 - MRC
- LeeMarshall
- 1st Gear
Hi Oli,that would be great! i am based in Tamworth, where are you? i dont have a vagcom so would be good to see if anything else comes up? i think i can poss fix the abs module as i have done lots of soldering.Tomorrow would be good for me,where you thinking of? Cheers Lee
Hi mate, if you can fix yours maybe we can do mine too! haha
tamworth is pretty far from me, about 45mins can you get up north a bit towards stoke/newcastle way thats where i am.
Oli
Oli
S4 B5 - MRC
- LeeMarshall
- 1st Gear
Hi Oli,i only think i can? we wil see? got the info how to fix from the link from UKS4APR1. have a look! i could meet you at stafford services if thats any good to you? Lee
Same here mate, i have done lots of soldering but my iron hasnt got a very sharp tip on for this kind of detailed work
stafford services would be fine, pm me your number
Ol
Ol
S4 B5 - MRC
- LeeMarshall
- 1st Gear
Hi again Oli, ifyou wanna ring me to sort something out my no is:07920132142 i am going out soon but will be back at about 7.30pm cheers Lee
Users browsing this forum: No registered users and 260 guests
