Anti-Roll Bars for the S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
BrilliantBlack
Post by BrilliantBlack » Thu Jul 13, 2006 1:44 pm
Most popular kits I've found are the H&R and Eibach ones. H&R cost about £100 more than the Eibach £200 asking price.
Has anyone had a go at fitting themselves.. preferably without owning a garage 8)
I'm thinking of having a go on my drive with two axle stands and a bag of luck... :D
s4woody
Post by s4woody » Thu Jul 13, 2006 1:46 pm
i did both my fronts and back myself..what area do you live in..
GARTH ROAD MOT CENTRE LTD
020 83353032
MarkB
Post by MarkB » Thu Jul 13, 2006 1:49 pm
Shouldn't be hard. Just make sure you lift the complete axle off the ground so as not to load the bar up at all.
Anyone know what the specs are for the Eibach bars?
Mark
s4gilly
Post by s4gilly » Thu Jul 13, 2006 5:41 pm
I had a look at the eibach arb and i was told that they do not do a rear bar. £200 is just the front bar as eibach say that the s4 doesnt need an uprated rear bar. IMO they are wrong!!!
DavidT
Post by DavidT » Thu Jul 13, 2006 10:01 pm
SimonS4MTM wrote:
s4woody wrote:i think if the links are made longer that will alter the angle of the arb which will change the reaction time surely..or even the leverage effect..you dnt see many racing cars with plastic suspension parts and i,m sure that even if we dnt quite grasp the reasons behind it they work better than oem..
Yes, I can see the benefit of fitting stiffer links, just cant see the point in making the length adjustable.
We had this debate a while back I think?
The length of the drop links has no effect on the torsional loads across the arb, it only affects where the arms sit, assuming the drop links are of equal length, which they should always be, racing applications aside.
There is nothing wrong with the oem drop links, they are plastic and have a bend in for a reason! That said, I will be having a set of yours if I get a H&R 21mm arb and cannot try it on the stiff setting s4woody.
BrilliantBlack
Post by BrilliantBlack » Thu Jul 13, 2006 10:28 pm
s4gilly wrote:I had a look at the eibach arb and i was told that they do not do a rear bar. £200 is just the front bar as eibach say that the s4 doesnt need an uprated rear bar. IMO they are wrong!!!
H&R this weekend it is then :wink:
Watch it.. it'll pi55 down! :evil:
Nige
DavidT
Post by DavidT » Thu Jul 13, 2006 10:37 pm
Nige
Doesn't matter, you'll be very happy when they're on :thumbs:
SimonS4MTM
Post by SimonS4MTM » Fri Jul 14, 2006 9:04 am
I must get round to fitting mine soon as well.
KayGee
Post by KayGee » Fri Jul 14, 2006 10:42 am
I must get round to buying some soon....
SimonS4MTM
Post by SimonS4MTM » Fri Jul 14, 2006 10:48 am
On the subject of ARB's and not really off topic, are the standard S4/RS4 arb's thicker than those fitted to the A4
DavidT
Post by DavidT » Fri Jul 14, 2006 6:27 pm
I expect so Simon, the engine is heavier for one thing. I think the OEM S4 ones are 28 & 15 mm.
KayGee
Post by KayGee » Sat Jul 15, 2006 12:44 am
According to ETKA S4s 29mm and 15mm. A4s are 29 and either 15 or 12.5mm depending on whether they have sports suspension. Interestingly RS4 uses the same part numbers, optional Quattro gmbh rear AR bars of 17mm.
DavidT
Post by DavidT » Sat Jul 15, 2006 9:57 am
Cheers Kevin, interesting.
edit, sorry, hit the wrong button and submitted before I'd finished
that the lowliest A4 (a 1.6?) had the same front arb as the S4 and RS4. I doubt they would do that now.
KayGee
Post by KayGee » Sat Jul 15, 2006 12:06 pm
me too....I also thought RS4 had different ARBs to the S4, nearly bought some of ebay a few months back.
8D0 411 309 L or M depending on sports suspension or standard suspension.....
Users browsing this forum: No registered users and 141 guests
