specs of standard battery.
dhali
Post by dhali » Fri Jul 14, 2006 5:00 pm
sorry if this has been asked before, but what are the specs of the standard battery in a RS4? As mine has finally given up the ghost. will be going to costco tonite and have heard they do bosch batteries at a reasonable price.
dummi
RE: specs of standard battery.
Post by dummi » Fri Jul 14, 2006 5:16 pm
have you tried checking your part number... failing that measure the dimensions of your batt height width length and get one with atleast the the same cca and sustained output and your done i would think..
dhali
Post by dhali » Fri Jul 14, 2006 5:28 pm
output thats what i wanted to know? where?how can i find this out? will it be on the battery?
dummi
Post by dummi » Fri Jul 14, 2006 8:47 pm
yeah there will be a small number in Ah that will tell you how much current it can sustain and a bigger number that is in Ah that will tell you that cold cranking amps it can give to start your motor HTH
Nige_RS4
Post by Nige_RS4 » Fri Jul 14, 2006 8:49 pm
Std battery is 340A/70Ah, however it is quite difficult to get an aftermarket one with exactly the same spec. I opted for a 530A/66Ah from these guys .... http://www.tayna.co.uk/item/991/0/067-N ... page1.html
Next day delivery for £5.95 - couldn't fault them!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
dhali
Post by dhali » Fri Jul 14, 2006 9:49 pm
took mine out and had a look says following on side:
12V 70AH
570A EN/SAE
000915105AE,
had a look at costco , they do Bosch one for Audi 12v 75ah £55.21 inc. with 4yr warranty..
dummi
Post by dummi » Fri Jul 14, 2006 11:17 pm
on your standard battery the 70ah is sustained and the 570a is the cold cranking for your starter
on your new one 75ah is plenty sustained, make sure cold cranking is the same or more than you had then the starter will work as it should
hth
dhali
Post by dhali » Sat Jul 15, 2006 10:07 am
thanks guys.
Return to “Electrical”
Users browsing this forum: No registered users and 31 guests
