up rated side mount intercooler B5 Rs4 MTM Sportec Dahlback
not meaning to say Rs4 and there like inter coolers are not good enough, as they clearly are according to Awe and for any one up grading from s4 you can be sure you are getting a superb improvement.
That said many rs4 owners feel the need to up grade.
I would love an fmic but so many people have gone this route and had to butcher the front end throwing up many new cooling issues and altering the ease with which the front end works. I do not want all the issues an fmic will bring. (but I still may surcome)
I know there are 2" of extra width not utilised by the rs4 intercoolers on the outside of the bumper, as I currently run a 2" brake duck cooling hose down this gap
So based on my own knowledge regarding the width and the dimensions of the intercooler Awe have made, it is lightly you could widen the rs intercooler to 11.5 inches and lengthen it by 2 inches as the top and bottom of the Awe clearly show that the rs pipes on the rs intercooler come out in a more efficient way thus allowing for more improvement on design.
I believe Sportec did bigger Rs side mounts can any one help with this? Supplier Cost and dimensions.
Also Dahlback appear to have a solution and I expect this is also utilised by mtm, but I cant find any info from the net. Again Supplier Cost and dimensions if any one can help.
Here are the big babies on the 570 bhp Dahlback car. Huh...
- Attachments
- interc.jpg (15.66 KiB) Viewed 882 times
- rs4_5.jpg (13.57 KiB) Viewed 880 times
- rs4_3.jpg (16.48 KiB) Viewed 878 times
RE: up rated side mount intercooler B5 Rs4 MTM Sportec Dahlb
I can help out Gordon - I will send you a pm.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Beacause it's early days, so I don't have much to tell. These will probably not fit the S4 unless you have an RS4 bumber and IC pipes BTW.Why not share the knowledge?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
The AWE IC's are something like 57% larger core surface area than stock RS4 - is this not big enough for you? How much bigger are these bad boys..?
Clive
I think the AWE coolers are good but they get their surface area from being deeper which isn't all good, the air getting warmer as it travels through the fins. I think these guys are wanting a larger frontal area...
Mark
When I was reading the AWE site, I got the impression (from AWE's own tests) that the AWE ones are only marginally better than OEM RS4 - is that correct?
Yes, I'd like to better understand what is going on here.
Although the RS4 IC's are only 6%(?) larger than S4, the RS4 IC pipework is larger resulting in better flow? The AWE pipes are same size as S4.
The pipes on this look RS4 size...
Clive
Re: RE: up rated side mount intercooler B5 Rs4 MTM Sportec D
David,DavidT wrote:When I was reading the AWE site, I got the impression (from AWE's own tests) that the AWE ones are only marginally better than OEM RS4 - is that correct?
The AWE site shows some pretty impressive graphs, but I'm not sure what to conclude from them, to be honest...
Clive
RE: Re: RE: up rated side mount intercooler B5 Rs4 MTM Sport
Correct assumptionI think the AWE coolers are good but they get their surface area from being deeper which isn't all good, the air getting warmer as it travels through the fins. I think these guys are wanting a larger frontal area...
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
I've got the Sportec IC dimensions at home - I will post them tonight, but they are defo wider and taller than the RS4 units and a little bit deeper too.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
There is a photo on here somwhere of Andiroo's sportec i/c install. Very impressive.
Thanks Nige
Will be interesting to see how it compares with these :
- Attachments
- Intercooler dimensions.jpg (114.79 KiB) Viewed 824 times
Clive
Re: RE: Re: RE: up rated side mount intercooler B5 Rs4 MTM S
Gotta link David?DavidT wrote:There is a photo on here somwhere of Andiroo's sportec i/c install. Very impressive.
Clive
Users browsing this forum: Google [Bot] and 61 guests
