Anti-Roll Bars for the S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
MarkB
Post by MarkB » Tue Jul 11, 2006 1:41 pm
How much do they normaly cost?
Mark
s4woody
Post by s4woody » Tue Jul 11, 2006 2:00 pm
mark u get em and i,ll fit them if ya fancy a run out to sutton..can make a mini meet out of it if u want..
GARTH ROAD MOT CENTRE LTD
020 83353032
CliveH
Post by CliveH » Tue Jul 11, 2006 2:02 pm
About £400 F&R.
Clive
MarkB
Post by MarkB » Tue Jul 11, 2006 2:04 pm
Thanks for the offer, all pie in the sky for now. Still got brakes, springs, IC's etc etc to fit first.
Just been on the phone with Jimbogrey and we talked about a mini meet...
Mark
s4woody
Post by s4woody » Tue Jul 11, 2006 2:04 pm
think i paid alittle less than that from phillip walker..i,ll try and dig out a receipt..
020 83353032
MarkB
Post by MarkB » Tue Jul 11, 2006 2:05 pm
CliveH wrote:About £400 F&R.
I think I'll be waiting for some second hand.
Mark
s4woody
Post by s4woody » Tue Jul 11, 2006 2:08 pm
300 all in to your door..thick or thin arb's..
020 83353032
MarkB
Post by MarkB » Tue Jul 11, 2006 2:10 pm
That sounds a bit better, will still have to wait a while...
Mark
tartan_rob
Post by tartan_rob » Tue Jul 11, 2006 3:21 pm
I run std shockers, Eibach springs and H&R ARB's, 32/21's.
I think the suspension is absolutely spot on. At times I think it may be a little soft but it holds the road like a shitty blanket and any harder may be uncomfortable on longer runs. I am running the soft option on the rear ARB's but thinking about changing drop links to run the harder option to see what that does to turn in.
2017 Kawasaki Z1000
2014 RS6
2014 S1
MarkB
Post by MarkB » Tue Jul 11, 2006 3:31 pm
Good to know, thanks Rob.
Mark
s4gilly
Post by s4gilly » Tue Jul 11, 2006 5:42 pm
Do u need to upgrade the droplinks if running the harder setting Rob?
Been running mine for a month on the hardest seting with standard drop links and everythings fine so far(touch wood :bash: ) Took a little getting used to over the standard roll bars because the back is so much more solid. I would get them done asap. very good mod :)
tartan_rob
Post by tartan_rob » Wed Jul 12, 2006 8:03 am
I could get my rear ARB's to work with the drop links on hard setting. The drop links foul the driveshafts. Thee modded ones stop the fouling. Are you sure you are running on the harder setting if you have std drop links?
2017 Kawasaki Z1000
2014 RS6
2014 S1
s4-99
Post by s4-99 » Wed Jul 12, 2006 3:25 pm
Rob i have standard drop links and i'm also on the hard setting. No problems so far!!!
Hmmm, its fast but is it fast enough!!!
ZeroK66
Post by ZeroK66 » Wed Jul 12, 2006 4:19 pm
Facelift make a diff - you a facelift Rob?? I will probably replace my droplinks just incase.
s4woody
Post by s4woody » Wed Jul 12, 2006 6:45 pm
i think some one should determine exactly what 1 of the 2 holes there using on the rear arb so we know whats hard and whats the oem setting..
my understanding is that the hole towards the front of the car is the hard setting and the hole nearest the bend in the arb is the oem setting..is this correct..??
020 83353032
