Anti-Roll Bars for the S4
mark u get em and i,ll fit them if ya fancy a run out to sutton..can make a mini meet out of it if u want..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
About £400 F&R.
Clive
tartan_rob
I run std shockers, Eibach springs and H&R ARB's, 32/21's.
I think the suspension is absolutely spot on. At times I think it may be a little soft but it holds the road like a shitty blanket and any harder may be uncomfortable on longer runs. I am running the soft option on the rear ARB's but thinking about changing drop links to run the harder option to see what that does to turn in.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Do u need to upgrade the droplinks if running the harder setting Rob?
Been running mine for a month on the hardest seting with standard drop links and everythings fine so far(touch wood
) Took a little getting used to over the standard roll bars because the back is so much more solid. I would get them done asap. very good mod
tartan_rob
Facelift make a diff - you a facelift Rob?? I will probably replace my droplinks just incase.
i think some one should determine exactly what 1 of the 2 holes there using on the rear arb so we know whats hard and whats the oem setting..
my understanding is that the hole towards the front of the car is the hard setting and the hole nearest the bend in the arb is the oem setting..is this correct..??
020 83353032
020 83353032
Users browsing this forum: No registered users and 65 guests
