Calling Tartan Rob How is your RS6 Hybrids coming
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Nige_RS4
Post by Nige_RS4 » Tue Jun 13, 2006 11:53 am
And are rs6 hybrids the standard turbos that are in rs6's? They ported over to the S4 untouched or are they modified?
Saf, the whole point of them being called hybrids is that they are made up of an assortment of turbo parts. The benefits of hybrid turbos can typically be an increase in flow rates without any undue increase in lag. The downside is unproven reliability - not so bad on the 1.8T engine, as it's relatively easy to change the turbo, but on the S4 .......
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
saf
Post by saf » Tue Jun 13, 2006 12:07 pm
So I guess for an upgrade from K03's its probably best to go for standard K04's right? and I should think simpler too.
Also when you say unproven reliability what do you mean by that?
RIght I thought they were called hybrids because RS6 used the RS4 K04s but they were put together in different casing. So that means, the K04's were taken from the RS6 and modified to fit into an S4 or RS4.
I guess were all waiting for Tatran Rob. lol.
Nige_RS4
Post by Nige_RS4 » Tue Jun 13, 2006 12:26 pm
Hi saf, depends on how far you want to take your car - 400'ish bhp, I don't see the point in spending £3-4k on turbos. If you want 500+ horses, then you should consider (need) the hybrids.
Regarding reliability, there's not enough of the hybrids out there with a fair few miles on them to make a judgement call on reliability.
The RS6 has it's own version of the KKK series of turbos - hybrids are not OEM, therefore you can't buy them from Audi etc...
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
saf
Post by saf » Tue Jun 13, 2006 12:38 pm
I see. So whats the most BHP you can get on standard K04's having done all the other little bits? Like ic's, oil cooler, clutch, injectors all rs4 spec?
I thought you could get up to near 450 being reasonable. Anymore then youd need hybrids right?
Do you also know what torque levels are attainable using standard K04's (nm) and then the hybrids? even a rough estimate would be nice to know.
Thanks for all the info.
Where are best places to get them from?
Nige_RS4
Post by Nige_RS4 » Tue Jun 13, 2006 1:40 pm
K04's are good for 500bhp or so on an RS4, hence why I said 500+ for hybrids. If you stick with K04's and a remap, expect 400 or so horses. If you add fuelling, MAF, IC upgrades then you can get closer to 440, but it does start getting expensive when you add up the parts required.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
dummi
Post by dummi » Wed Jun 14, 2006 1:10 pm
yes make sure you are willing to pay the costs and some before you take apart the car in the same way that i didn't :lol: but really should be an awesome machine with the hybrids but slapping on some k04's + remap is way cheaper
s4woody
Post by s4woody » Wed Jun 14, 2006 7:31 pm
so far i have k04,s green top injectors,rs4 maf,airbox,y pipe,ic,s,all metal charge pipes and even got the inlet manifold and throttle body..so all i need is the fuel pump then i have all the inlet from an rs4..total about 2000 pounds but i mite go mad and get some tubular manifolds just to finish it off..if when its done if i see around 450bhp i,ll be smiling..if i dnt see it i,ll be getting more stuff till i reach it..thats my goal..
GARTH ROAD MOT CENTRE LTD
020 83353032
KayGee
Post by KayGee » Thu Jun 15, 2006 12:05 am
If your doing the IM and throttle body, I'd slap some NA heads on it as well. Should be another stage 3 beast of a car.
s4woody
Post by s4woody » Thu Jun 15, 2006 12:09 am
i couldnt agree more kaygee..im just storing parts at the mo so if some heads come up i,ll grab em..not in a rush and i find that the parts find me... :redrs4:
020 83353032
tartan_rob
Post by tartan_rob » Fri Jun 16, 2006 1:18 pm
Guys - I'm just back from vacation (hence my absence from the forum) and the car is back together but unfortunately Mihnea has been off sick so it has not been remapped and running crap on std map so I've left her with MRC until next week when Mihnea will be back.
So far I have had the following fitted:
- Hot side modification to Ported Hybrid turbo's
- Exhaust manifolds for new OE ones
- All mounts
- RS4 intercoolers
- Starter motor
- RS4 Clutch
- RS4 flywheel
- Uprated fuel pump (I think Bosch motorsport one - whatever MRC recommended)
- Large injectors
- New pipework
This is coupled to dual Milltek catback and std downpipe with gutted pre-cats.
I'll keep you posted...
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
tartan_rob
Post by tartan_rob » Fri Jun 16, 2006 1:20 pm
And the best bit that I forgot to mention, I have a set of 1.9Tdi badges that she will be re-bagded as.
+ all gaskets and aux water pump
2017 Kawasaki Z1000
2014 RS6
2014 S1
BaSen
Post by BaSen » Fri Jun 16, 2006 1:39 pm
Ouch, it's gonna be a killer-car :D
Nogaroblue Saloon S4, RS4 clutch, B&M shortshifter, Rieger RS4 front bumper, Dahlback Racing DV's.
Coming soon: K04's, RS4 ic:s, Dahlback Racing custom engine remap, Dahlback Racing exhaust etc etc!
http://www.garaget.org/?car=3469
MarkB
Post by MarkB » Fri Jun 16, 2006 1:44 pm
Can't wait to here how it goes after the remap...
Mark
oliew
:P
Post by oliew » Fri Jun 16, 2006 2:08 pm
sounds awesome rob
:twisted:
S4 B5 - MRC
andy1234
RE: :P
Post by andy1234 » Fri Jun 16, 2006 3:41 pm
loving the badges idea. There going to be alot of very depressed porsche/bmw etc owners being smoked by a 1.9tdi!
my cars for sale :(
Users browsing this forum: No registered users and 109 guests
