S3 Big Turbo (Downpipe Info needed)
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
242spot
Post by 242spot » Sun May 14, 2006 3:51 pm
Hey guys just a quick question about downpipes.
I have got a new turbo coming from ATP in the Sates (http://www.atpturbo.com/Merchant2/merch ... Code=VVWTK)
As most of you probably know the miltek exhaust does not include a downpipe. The only option i can find is APR on awesome GTI. But at 1000 Pounds its on the steep side.
Does anyone have some info on 3" downpipes for the standard configuration turbo mount.
Will keep you posted on how the turbo goes!!
Scott
Ryan_s3
RE: S3 Big Turbo (Downpipe Info needed)
Post by Ryan_s3 » Sun May 14, 2006 5:14 pm
Get H&S to fab you one up.
Image360bhp 342lb/t
242spot
H&S
Post by 242spot » Sun May 14, 2006 11:03 pm
Does this H&S place have a web site?
Have you had this done
DuncS3
RE: H&S
Post by DuncS3 » Mon May 15, 2006 10:17 am
Teemu
RE: H&S
Post by Teemu » Tue May 16, 2006 9:57 am
What manifold are you going to use?
Ryan_s3
RE: H&S
Post by Ryan_s3 » Tue May 16, 2006 5:05 pm
he is planning on using the standard manifold i guess with the eliminator gt28rs from atp.
Image360bhp 342lb/t
242spot
Post by 242spot » Wed May 17, 2006 7:58 am
Yip that right the best things about the eliminator is that with some slight plumbing changes it bolts straight on!!
Bigger injectors and the right map and your laughing
BlackS3
Post by BlackS3 » Wed May 17, 2006 3:36 pm
Thought a high flow manifold was a must for turbo upgrades??? Jabbasport supply Cosworth with them for their 300bhp 1.8t lumps
Ryan_s3
Post by Ryan_s3 » Wed May 17, 2006 6:37 pm
Yep standard manifold is crap,even the k03 turbo car manifolds are better,it will restict the turbo.
Mine has the jabbasport manifold and your right cosworth do buy it from them and have tested it.
Image360bhp 342lb/t
BlackS3
Post by BlackS3 » Thu May 18, 2006 2:08 pm
How much is the manifold? Should I pop one on mine with a standard exhaust or save for a Miltek system and do the lot together?
Ryan what year is your baby?
Ryan_s3
Post by Ryan_s3 » Thu May 18, 2006 3:31 pm
Mine is a 1999. You only need this manifold if you are fitting a ihi turbo,standard exhaust is a waste of time with a big turbo,some miltek's are restictive too.
What is your plan?
Image360bhp 342lb/t
stevett
Post by stevett » Sat May 20, 2006 5:03 pm
also try http://www.autops.co.uk/contact.php they use a local firm who fabricate catch tanks,hard pipes,polished exhaust systems and dp's!
MRC AUDI TT 415BHP/398FTLBS
0-60 4.1SECS,1/4MILE 12.4SECS
david7m
Post by david7m » Sun May 21, 2006 3:03 pm
242spot wrote:Yip that right the best things about the eliminator is that with some slight plumbing changes it bolts straight on!!
What bhp you expecting? Total cost?
Cheers,
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
242spot
Post by 242spot » Sun May 21, 2006 3:38 pm
Ok to those of you who have aftermarket maniforlds the only reason you have them is to MATE the turbo up. The flow of the mainfold is really irrelevant in this application. This Information comes from my friend @ garret who spends his time testing things like this.
Im not going to use the turbo that ATP spec, my friend has custom spect a slightly smaller unit. The ATP one is to big .....TO much lag.
The smaller one wont push 400bhp like the ATP can, but it will give me a useable 310-330bhp for1/4 the price of MTM.
Of course bigger injectors and im thinking of using a MOTEC ECU which wont come cheap but is the best on the market.
Cost dont know yet...... mates rates
david7m
Post by david7m » Sun May 21, 2006 5:11 pm
Fair enough, was just trying to get some idea, as I'd like some more grunt in my S3.
Not sure if the 2007 R1 on this weeks MCN cover is the way forward though :)
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: No registered users and 10 guests
