Wheel Caliper problem!!
2.7 V6 30v biturbo - 380 bhp
RED_ROCKET
Post by RED_ROCKET » Sat May 13, 2006 12:07 am
Just instaled B7 disc and Calipers.
Problem: Wheels hitting calipers.
Resolve: Already got 10mm spacers. May go for 15mm sapcers but rims will hit the arches.
Anyone here with advise.
Using 9.5 x 19 BBS LMs 32 offset (bigdish)
Advice. :?
993 Gt2 - Mid life crisis
RS4 B5 -(Disappeared)
Q7 - Family wagon (RIP)
dodgydave
RE: Wheel Caliper problem!!
Post by dodgydave » Sat May 13, 2006 12:46 am
I drive 20mm spacers with 19 inch et 32 and I got 1.5 cm to the rs6/new rs4 calipers and the wheels are just a hairs braid from touching my arches .... so i guess 9.5 is a bit too wide ...sorry
Never enough...
dodgydave
Re: RE: Wheel Caliper problem!!
Post by dodgydave » Sat May 13, 2006 12:47 am
dodgydave wrote:I drive 20mm spacers with 19 inch et 32 and I got 1.5 cm to the rs6/new rs4 calipers and the wheels are just a hairs braid from touching my arches .... so i guess 9.5 is a bit too wide ...sorry
8 inch wheels btw
dodgydave
Post by dodgydave » Sat May 13, 2006 12:51 am
8 inch wheels btw
RED_ROCKET
RE: Re: RE: Wheel Caliper problem!!
Post by RED_ROCKET » Sat May 13, 2006 9:45 am
Sql_RS4
Post by Sql_RS4 » Sat May 13, 2006 12:16 pm
Please let me know if this set of B7 brakes makes a lot of difference?
I still have a lot of wear on my original discs and pads and am now thinking if it is worth replacing them now or is it better to wait until my original ones wear out...
Hutch
Post by Hutch » Sat May 13, 2006 8:35 pm
I have tried these wheels with 12mm spacers and they do not fit over the movit calipers
Looks like 15mm spacers might be enough and by the sounds of it the arches will need to be rolled.
Only other option is to machine the inside of the rim down by 3mm. I won't be doing this.
RED_ROCKET
Post by RED_ROCKET » Sat May 13, 2006 11:10 pm
Headache upgrade!! more stress than its worth.
looks like new front alloys for me. No other options.
Dont recommend if you have BBS LMs...
help...
Taymir
Re: RE: Re: RE: Wheel Caliper problem!!
Post by Taymir » Sun May 14, 2006 12:17 am
RED_ROCKET wrote:Headache upgrade!! more stress than its worth.
help...
I just ordered BBS LM, I got AP racing brakes, dose anyone now will the rims fit ?
tartan_rob
RE: Re: RE: Re: RE: Wheel Caliper problem!!
Post by tartan_rob » Sun May 14, 2006 8:50 am
Can you not change the front wheels to same style but different offset?
2017 Kawasaki Z1000
2014 RS6
2014 S1
simple1
Post by simple1 » Sun May 14, 2006 9:30 am
Running AP brakes with 19" MTM wheels, use 20mm spacers on the front and 10mm on the rear... no issues with anything hitting.......As AP were designed to fit under 18" wheels there should be no issues
Golich
Post by Golich » Sun May 14, 2006 1:40 pm
Sql_RS4 wrote:Please let me know if this set of B7 brakes makes a lot of difference?
I tried the B7 brakes on Brooner's B5. I am not exaggerating when I say the difference is quite frankly UNBELIEVABLE and that was with his set up still needing to be bleed correctly.
I have my set waiting to be fitted when I get a spare moment.
RED_ROCKET
Re: RE: Re: RE: Re: RE: Wheel Caliper problem!!
Post by RED_ROCKET » Sun May 14, 2006 2:28 pm
simple1 wrote:Running AP brakes with 19" MTM wheels, use 20mm spacers on the front and 10mm on the rear... no issues with anything hitting.......As AP were designed to fit under 18" wheels there should be no issues
What are the offset on the wheels?
RED_ROCKET
Post by RED_ROCKET » Sun May 14, 2006 2:30 pm
help...
Should be ok for the AP's. But whats the Offset ?
Taymir
Post by Taymir » Sun May 14, 2006 8:46 pm
help...
I don’t know what offset, but they are 18" BBS LM, first I ordered 19" but then the waiting time for the order was too long and I decided that 18", considering our horrible roads in Moscow will be ok too :)
Users browsing this forum: Bing [Bot] and 93 guests
