Problem: Wheels hitting calipers.
Resolve: Already got 10mm spacers. May go for 15mm sapcers but rims will hit the arches.
Anyone here with advise.
Using 9.5 x 19 BBS LMs 32 offset (bigdish)
Advice.
8 inch wheels btwdodgydave wrote:I drive 20mm spacers with 19 inch et 32 and I got 1.5 cm to the rs6/new rs4 calipers and the wheels are just a hairs braid from touching my arches .... so i guess 9.5 is a bit too wide ...sorry
I just ordered BBS LM, I got AP racing brakes, dose anyone now will the rims fit ?RED_ROCKET wrote:Headache upgrade!! more stress than its worth.
looks like new front alloys for me. No other options.
Dont recommend if you have BBS LMs...
help...
I tried the B7 brakes on Brooner's B5. I am not exaggerating when I say the difference is quite frankly UNBELIEVABLE and that was with his set up still needing to be bleed correctly.Sql_RS4 wrote:Please let me know if this set of B7 brakes makes a lot of difference?
I still have a lot of wear on my original discs and pads and am now thinking if it is worth replacing them now or is it better to wait until my original ones wear out...
What are the offset on the wheels?simple1 wrote:Running AP brakes with 19" MTM wheels, use 20mm spacers on the front and 10mm on the rear... no issues with anything hitting.......As AP were designed to fit under 18" wheels there should be no issues
Should be ok for the AP's. But whats the Offset ?Taymir wrote:I just ordered BBS LM, I got AP racing brakes, dose anyone now will the rims fit ?RED_ROCKET wrote:Headache upgrade!! more stress than its worth.
help...
I don’t know what offset, but they are 18" BBS LM, first I ordered 19" but then the waiting time for the order was too long and I decided that 18", considering our horrible roads in Moscow will be ok tooRED_ROCKET wrote:Should be ok for the AP's. But whats the Offset ?Taymir wrote:I just ordered BBS LM, I got AP racing brakes, dose anyone now will the rims fit ?RED_ROCKET wrote:Headache upgrade!! more stress than its worth.
help...
